MJ'87
Everything posted by MJ'87
  1. they sell one in the 4wheel drive catalog i have. its the whole hood. :popcorn: 4wheel drive-"Beat the heat out on the trail and on the street! Adding style and function, this Steel Cowl Induction Hood from Refexxion looks cool and helps your Cherokee run cool by allowing under hood heat to escape through the raised, open rear cowl. A direct replacement for your factory hood, it is easily installed with ordinary tools. Hoods are finished in black primer that is ready to prep and paint. Hardware not included." $399.95 i guess by "hardware" they mean hood mounts.
  2. ok, cool. i'll look for a cover off a YJ in a junk yard
  3. AH HA! a common problem among the 4 cylinders. if you were to take the cover off and put it on a perfectly flat surface you will probably see that your plastic valve cover is warped :mad: . i have looked all over for a replacement metal cover but i havent had any luck :dunno: . if you happen to come across one, let me know where you got it.
  4. thats gonna be a sweet setup
  5. i like the hood
  6. i put a 5" lift for rocky-road.com on my '87 mj. its fine without the longer lower control arms, but i can't get too off camber or go over big bumps without my front tires rubbing flairs. id like to get em, but money is an issue.
  7. hey, thanks a lot. i'll have to put those on my list once i get enough money
  8. i thought i saw front fenders on here before. maybe i was mistaken. but thanks anyway
  9. does anyone know where i can get or what company makes flaired baja-style fiberglass fenders for a comanche?
  10. hey, thanks a lot. i'll inform you guys of anything else during my MJ project
  11. its a "T"
  12. thanks for the VIN thing. I'm gonna check right now. its an '89 4x2
  13. Ha, ha, "witch" yeah, thanks. I'm putting in a new clutch and the new pilot bushing doesnt fit in my flywheel. the guy at the shop said the 2.5 only had the 5-speed. i was wondering if the previous owner had swapped it with the one i have
  14. witch stick transmission was meant to go with the 2.5 4cyl MJ? mine has a 4-speed
  15. when i lift my MJ, what other parts will i need to replace. I'm not going for the cheap "add a leaf" or block kit, I'm gonna get the 5" full travel lift
  16. i found a comanche laredo in a junk yard with bucket seats in it. look around for one cuz the brackets match
  17. the bearing in the speedo is what was making the noise. i took the whole thing apart and lubed everything and now its silent
  18. on the way to school this morning i started to hear a really loud, kind of grinding sound coming from the dash. and then the needle in the speedometer started creeping up when i wasnt accelerating, then the needle started vibrating so much that it was bouncing between the gauge and the plastic. what happened
  19. I'm new here and just starting to get the hang of things. i just wanna know if anyone knows if there is an aluminum valve cover for my 2.5 liter motor in my '89 comanche
