furydan
furydan's Achievements
  1. I used a set of gaskets from them when rebuilding a 318 motor and have had zero leaks with their stuff. The machine shop I was working with got them for me. Dan
  2. Well using the bolt behing the ujoint trick worked wonderfully...got it off in about 5 minutes... Thanks for the advice.... Dan
  3. So for 2 days I have been trying to get the front hub off of the passenger side of my 88 4wd comanche 4cyl/4 speed. I took off the axle shaft nut and the three bolts holding the hub to steering knuckle. The hub will not budge. I used a 3 jaw puller and no go..The hub will not come off. I assume the hub is rusted on to the steering knuckle. How can I get this off.. Tomorrow I am borrowing an air chisel and trying to bust it loose. I have been spraying with pb blaster and hitting the mounting flange of the hub with a hammer and chisel..It just won't budge. It does look like the axle is moving a little in the bearing so I think it is the flange stuck to the steering knuckle. I am afraid to put too much pressure with the puller only because I don't want to hurt the axle shaft itself or the rear gear by pushing the axle into it. Any help would be much appreciated. Thanks Dan
  4. oops..My bad It is a 88 comanche with a 2.5l motor 4wd. My emission light is on..truck runs fine. It has been on since I got it. Haven't had it long. Still fixing brake lines.
  5. Where is the emissions maintenence timer located..I saw a picture of it , but can't find it in the truck. Dan
  6. Have you checked to make sure the fuel pump didn't quit on you? Can you hear it when you turn the key?
