quentin
Everything posted by quentin
  1. Kendal oil will cause that
  2. No I don't. Just got this Comanche. Do you have an idea about the brake lights ? Wire to switch is dead. Can run a wire direct to switch from fuse block and the work.
  3. Thanks.. I think I found it. Radio Wire had a bare spot in the wire that dims the lights ! Now to figure out how much damage it had done.. Probably the headlight switch for one.. fixed the wire, replaced fuse. have dash lights and interior (dome lite)
  4. No fluid leaking out of clutch master cylinder.. thanks
  5. Thanks.. I think I found it. Radio Wire had a bare spot in the wire that dims the lights ! Now to figure out how much damage it had done.. Probably the headlight switch for one..
  6. I have an '89 Comanche, 4cyl,4spd,2wd. Interior lights, dash lights and brake lights don't work. Any suggestions as what might be the problem. Thanks.
  7. Walker (Quentin) here . Marana Az. just getting on the site. '89 Comanche, 2WD, 4 cyl., 4 speed. Short bed. AC !This is my 6th Comanche. 92,000 original miles.
