Jerry Forrester
Everything posted by Jerry Forrester
Help!, My 'manche quit running
Jerry Forrester replied to Jerry Forrester's topic in MJ Tech: Modification and Repairs
Thanks hornbrod, I will check that out Monday. I switched the ASD and fuel pump relays today. Nothing changed. won't run. -
First, let me thank you for reading all the posts instead of just reading the last one and posing a solution that has been addressed several times already. Correct Correct. Correct and I have NOT replaced ANY wires. I will admit that I have not checked all the grounds. This Comanche has spent it's entire life in Georgia. We don't have the problem with corrosion here as much as some of the states which use salt on the roads. Notice I didn't say we have NO corrosion, just not as much. I'll check the grounds Monday. Thanks Scott, I'll get back to barking at it Monday and see if I can tree this coon. Jerry -
Thanks hornbrod, I will check that out Monday. -
Today I installed the NEW new CPS. won't run. Still getting a weak spark out of #4 dist. terminal and a weak double spark out of #1 dist. terminal. Help! Jerry -
It's a '91 4.0 High Output. 5 speed. When it first quit running, I put in a new CPS. won't run. Then I put in a remanufactured distributor. won't run. Then I returned that dist and got a new distributor. won't run. Jerry -
Thanks for the diagram and the pic. There doesn't look like there's anything with the flywheel that can cause this problem. Is there an ASD on my '91 4.0? How do I find it and how do I check it? I checked the codes by turning the ign. switch on three times and got an eleven and a fifty four. That's the CSS and CPS. I have replaced both of those with new items. I then disconnected the battery for ten minutes to erased the codes. Now all I get when I check the codes is the code twelve that starts the sequence and code fifty five to end the sequence. That reference gave me a picture of a CPS connection with three straight across pins. My '91 4.0 has three pins arranged in a triangular pattern with no A-B-or C on the connector. Thanks, Jerry -
I agree about the two stage compressor. It's the only way to go.
Oh yeah, I have checked the compression. Ranges from 110 to 125 lbs. Not ideal, but probably what one would expect from a 257,000 mile 4.0. I also have the valve cover off to check the movement of the rockers. Everything there looks good. I have never seen a Jeep flywheel that triggers a CPS. What does it look like? Is there something there that could be causing this problem? I'm grasping at straws here now. Jerry -
When I borrowed the noid light from my buddy, I checked only one injector's pulse and it had pulse. I borrowed it again and checked all the injector feeds. Got pulse on 2,3 and 6. Nothing on 1,4 and 5. Hooked the remote starter button up so I won't have to rely on someone else's interpretation of what is happening under the hood while I am cranking the engine over. At this point in time, I have the plugs out and the cap and rotor off. I spin the engine and check the spark coming out of the coil wire. I get two sparks (yellow), then a long pause, then two sparks, then a long pause. In other words, it's firing only two times per distributor revolution. I reinstall the cap and rotor and check the spark coming out of the distributor cap. I'm getting spark (yellow) out of terminals four and one. The funny (as if anything about this could be construed as funny) part is, the spark from number one terminal is a double spark and the spark from the number four terminal is a single spark. I have tried both ECM's and am getting the same exact results from both of them. So what we have now is, No pulse for injectors 1, 4, and 5. No spark for plugs 5, 3, 6, and 2. Weak yellow spark for plugs 1 and 4. I'm going back to the beginning. The CPS. The Haynes manual says to check continuity between terminal A and B on the CPS plug, if it is bad it will be closed. There are three pins in the CPS plug and NO A or B. But there is no continuity between any of the three pins. That is supposed to mean the CPS is good. (Remember, this is at the start of this fiasco.) I bought a new CPS and installed it. Wouldn't run. A couple of days ago I checked the 'new' CPS I had installed. It shows continuity between two of the three terminals. Does that mean I have a bad 'new' CPS? Yesterday I traded that 'new' CPS for another new CPS. That's as far as I have gotten so far. I'll have more to report later. Thanks for all the help. And please keep it coming. Jerry -
The battery is strong, less than a year old. But of course with all this cranking and no running it was getting a little low. But I have a good charger with the boost feature so that's no problem. I have narrowed it down to electrics, it's not a fuel problem. I have all the plugs out of it now to releave the stress all the cranking was putting on the starter. Don't wanna have to buy a new starter too on top of all the other stuff. thanks Jerry -
Thanks, tried it and it still won't run. -
Thanks deziped. I'll pick up a can of carb. cleaner on my way to the shop tomorrow morning and try that. I don't think I need to run a compression test because I have a hell-of-a vacuum pull through the throttle body. But because several people have asked me if I ran a compression test, I was going to run one. Got my old military surplus tester out (been using it since the early sixties) and find I don't have the long reach adapter to screw into the spark plug holes. I'll borrow one from my friend tomorrow and do the compression test. I'll let you know the results. Jerry -
The used ECU came in today. Had it installed about 15 minutes after the UPS guy left. Still won't run! :mad: :help: -
What language is that? Cop talk or something? :nuts: Jerry
Okay, I lied. I wasn't able to let him sit. Several guys around here have told me that they thought I had a bad reman. distributor. I talked my guy at O'Rileys into letting me return the reman. dist. and selling me a new dist. The new dist. comes with a cap and rotor, (I had to buy the cap and rotor for the reman. unit separate), he let me return them too. :banana: I installed the NEW dist. Fri. afternoon. Guess what. won't run! Have any of you guys got an ECM to sell me cheap? Remember, it's a '91 5 speed. There's a used one on the bay right now for $60, free shipping. He claims it came out of a running '91 Comanche. He'll accept returns but I'll have to pay the shipping back to him. Sounds like a good deal. He has almost 4000 sales and a 100% feedback rating, but I would trust a guy on this forum more. BTY, I have almost 1200 sales and a 100% feedback so I know how hard it is to keep a 100% rating. Sometimes you have to do some crazy stuff to make 100% of your customers happy. Jerry -
First, I would take the threaded rod back out and thread on another nut jammed against the nut you have already welded on, so I would have enough meat to cross drill it for a lock. Then I would weld a 1/8 X 1" X 3" plate at 90 degrees onto the end of a 7/16" X 5" rod. Drill the end of the plate for access for the lock. Drop the 7/16" rod down through one of the wheel's lug holes and lock the fixture to the double nutted threaded rod. Or, rather than double nutting the threaded rod, weld a 1/4" X 1" X 1" flat (drilled for the lock) vertical onto the nut you have welded onto the threaded rod to lock them together. Use an adjustable wrench to screw the bolt in and out of the spare wheel. Jerry
I'm so upset with that black POS I didn't touch it yesterday. Devoted all my time to the Studebaker. Will probably do the same today. No recent repair work had been done. Other than gas and one quart of oil, nothing was done in the last 3500 miles. How can a person go from loving a 'manche one week and hating it the next? As far as the cat. goes, I've never had one to stop up all of a sudden. The 'manche went from running perfect to not running in a matter two minutes (the time it takes for a traffic light to cycle). I check the fuel mileage with every tank, it always gets between 17.5 and 18 MPG right up to when it stopped running. Has 150 miles on this tank of gas. I think I'm gonna let it set until Monday, then start in on it again. thanks for all the suggestions, keep 'em coming. Jerry -
Installed the new cap and rotor. won't run.:-( Jerry -
Crap! Have to learn to read (and retain) better. :oops: I know you have tried a new ECU. Look at the connector pins closely for recessing. Nope, haven't tried a new ECU yet. RockAuto.com wants almost $180 for one. I didn't price one from O'Riley's yet. I did disconnect the ECU and inspect the connection for recessed connections and corrosion. It all looked good. I'm starting to get discouraged and need to slow down. While disconnecting the ECU, I had to remove the top of the air cleaner box and I broke the hard line going from the valve cover to the air cleaner. Drat, now there's something else I have to fix. I want to thank all you guys for the help y'all are trying to give. Keep the suggestions coming. Jerry -
Here's my 'manche peeking his nose out of door #1. That's my '55 Stude Commander peeking out of door #2. For the last 18 months I've spent most on my extra time on restoring the Stude, but for the last 7 days my time has been split between the Stude and the 'manche. There's also my 425 Caddy powered pick up/dump truck. -
Since the engine is firing and seems to be getting the spark at the correct time, if I pour gas onto the throttle body, I'm sure the engine will run. I will try that tomorrow. But that's still not going to tell me what it takes to fix it. Jerry I was wrong. I removed the air intake from the throttle body and poured a couple of tablespoons of gas in there. It would not fire. I then poured a couple of tablespoons of lacquer thinner in and it still didn't fire. One more time I removed the distributor cap and turned the engine to where the rotor was pointing directly toward the #1 plug wire terminal. Looked at the TDC mark on the balancer and it was dead on. Next step, new cap and rotor. Now I'm grasping at straws. Maybe I need to check the air in the tires. Jerry -
Like I said, I know nothing about computer controlled cars. I was under the assumption that the ECM was a computer, but whatdoiknow. Jerry -
I've already installed a new coil. from my previous post...... I get Robert to help me check the fire coming out of the plug wires. I hand him a phillips screwdriver to put into the plug wire and I crank the engine over. He yells and throws the screwdriver across the shop. I had inadvertently given him a screwdriver with the metal shank going all the way through the handle. I got another screwdriver and we checked it again. He said there is very little spark. I asked him why he had jumped and yelled so much before and he said evidently very little spark will still light you up. I go to O'Riley's and get a new coil. Install it and the 'manche still won't run. we check the spark again and are getting an inch or so of spark, but it's orange, not the blue that it's supposed to be. -
No, not one that will interchange with my 'manche. There is an auto repair shop a half mile up the road from me. Operated by Scott. Scott is one of the best automotive mechanics in the area and is a personal friend. He has a customer's Dodge Caravan in his shop with all the same symptoms (codes) as my 'manche. He has done all the same things to the Caravan as I have to the 'manche plus, he has tried a new ECM with no positive response. Jerry A little history about me.... I'm street rodder and an ex-dirt track race car builder and driver. In the 40's my dad (he was also a dirt tracker) had a auto repair shop next door to our residence and I more or less grew up in that garage. I'm 68 years old and have been working on cars and trucks all my life. I was a mechanic in the Marine Corp in the sixties and a couple of other times in my life that's how I made my living. I am a retired mechanic from the trucking industry and receive a retirement check from the Teamsters Union for my service. If this was a carburated-non computer car there would be no problem. I can read and follow instructions but just don't have much experience repairing computer controlled cars. I guess you would call me 'old school'. -
