GM-Comanche
Everything posted by GM-Comanche
  1. Where did you get your USB outlet?
  2. I have a sliding rear window and would prefer solid
  3. Thanks ha, gonna do 97^ swap and wanted to keep from spending fortune on flares for them to match, ahh well ha i'll figure somethin out
  4. Anyone know if 97^ XJ rear flares will work on a MJ?
  5. Do you have a solid rear window right now?
  6. ill give it a shot ha
  7. Is there a program you use to "paint" your truck on the computer? Would be great to be able to do so i can narrow down a few colors ha
  8. The swap really didn't cost me much because I was able to sell a lot of what I didn't use and my donor didn't cost much. The paint job was pretty cheap for what it was at $1500. The stuff that was expensive was my seats, tires, lift, wheels, etc. Not bad at all for paint job, I've accumulated doors and fenders, wiring harness, motor and tranny, plus wheels. So all in all shouldn be too bad. My only prob is i need new rockers welded in and have rust on my bed, have tried to find another bed but there's hardly anything out there any better than what i've got
  9. Thanks sounds like a plan
  10. On the patch panels noticed there are no fender flare holes
  11. I'm putting the new dash out of newer cherokee in my MJ, anyone know how i go about the vin numbers on the two. Easy as just switching them? Legal issues?
  12. Thought about that, but wanting to keep bench seat
  13. Anybody come up with good center console for these things? With cup holders?
  14. I have plans to do the same to my comanche, just out of curiosity how much do you have in the swap? paint job?
  15. Have an 89 comanche, took a dash out of 98 cherokee, plus engine, tranny, and wiring harness. Plan is toput it all in my MJ. Has anyone done this? If so is it pretty simple? Fitment issues? Anything will help!!! Thanks!!!
  16. Thanks for the help everyone!
  17. Picked up a set of 16" rubicon wheels to put on my comanche, the bolt pattern is right, but wheels will not slide all the way on. Has any done this on their MJ?
  18. Does anyone know where to get a tailight wiring harness, or have a diagram for antidisestablishmentarianism wire goes where, mine are all messed up.
  19. Thanks i'll try those out!
  20. Dash lights don't work and have to turn left turn signal on to shut off left tailight. Any Ideas?
