Ricky8227
Everything posted by Ricky8227
Alright decided to just cut off the factory leaf hangers that the previous owner cut and moved back, and I’m going to just weld them back in the original position. I am ordering general springs stock Comanche leafs and will be running those. And I will be ordering a new custom length driveshaft as well. What shackles should I run?
Found the nightmare (reason axle is not centered)
Ricky8227 replied to Ricky8227's topic in MJ Tech: Modification and Repairs
Could I remove just one leaf? If so which one would be best to remove? -
The jeep drives good. Cruises at 70 mph no problem on 35s. I’m just trying to figure out if there is way to lower the rear end 1.5-2”. Without replacing the whole rear end. I’m going to try xj shackles cause the ones that are on there now seem so massive. -
Thank you for your reply. My goal is to not have to cut and move the front leaf hangers. If I were to just replace the shackles to xj ones will that lower the rear end? The spring packs that are on this axle are 6 leafs thick.. just seems way over kill. That’s why I was thinking about removing the bottom 2 leafs and adding xj shackles. This won’t be a wheeling rig. Just a grocery getter. -
Thank you. What would I do about the shackles if I go the route of doing the mj springs, and removing a leaf? These things are long lol -
Expect the rear is my problem here -
Yes the driveshaft looks to be lengthened. I believe it has had a 4x4 swap by the looks of everything. If I put the factory mount back in its original spot, what springs should I get? I want to have a 4”ish lift in the back. Not 6”. -
Yeah but these are not factory locations. It’s like he wanted to stretch the axle back. Don’t understand why. And the drivers rear tire is further back towards the rear than the passenger side. So the axle is crooked -
So just realized the previous owner cut the factory leaf mounts and slid them back lol. And the best part is they aren’t even equal distance. The right side is 1/4 inch further back than the left side. And the perches he welded on for the Chrysler 8.25 are off 1/4 inch as well. So the axle is all out of wack. So I figure the only way to fix is by cutting off brackets on the unibody, and put them back into factory position. Also will have to re weld the perches so they are actually centered. Anybody know what leaf spring mounts I can use instead of trying to re weld the factory ones back in place? What a disaster lol
Why is the rear wheel so far back off centered?
already ordered them! -
Yeah already have the panels from quadratec that I will be installing! -
How to lower the rear 1.5-2 inches?
Thanks guys I appreciate it. I was reading on other forms and people said that the xj shackles messed with the pinion angle and caused vibes? Would it just be better to remove bottom 2 leafs and get mj shackles or maybe get a set of adjustable shackles and leave the leafs in? -
Best way to lower the rear a couple inches? Remove a leaf? If so which is the best one to remove? The front is lifted about 6 inches and the rear looks to be like 8.
