Everything posted by littlezeeker
Project Tough Truck
littlezeeker replied to littlezeeker's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Had to make a new under armor for my gas tank :USAflag: Refuel time -
Project Tough Truck
New cab lights :banana: thought about going green what you think ? -
Project Tough Truck
:banana: new 33 inch tires :banana: -
Project Tough Truck
3 feet of articulation :thumbsup: -
Project Tough Truck
And still has plenty on power to burn the tires with the 4.11 gears -
Project Tough Truck
I still have the 2.5 and now on 33's I'll try to post a lot more pictures tonight I've been behind on photos -
Help finding a new flywheel
littlezeeker replied to littlezeeker's topic in MJ Tech: Modification and Repairs
Ok so I need the whole flywheel because the cluch went out and Ruined the Surface on the flywheel even though all the Teeth are fine, so does the 1987 2.5L ax-5 manual flywheel on rockauto like "mountainman"said work for my 1986 2.5L ax-5 manual flywheel ????? Cause it's the closes I've found yet thank you guys :wrench: -
Ok thanks guys ill give him a call and see if he can get it for me. -
I have a 86 jeep Comanche with the 2.5l and the ax15? It's the five speed manual and I can't seam to find the flywheel anywhere online or in local stores can anyone help maybe another year model or something can work on it ? Thank you for your help guys :bowdown:
Project Tough Truck
I got my new stickers finally :banana: -
Project Tough Truck
a few more youtube videos i need to get a few more real videos not just slide shows 4RjpnPiIheg&feature=g-upl bKOE8Xl6-Iw&feature=g-upl this is a small video of a flex test only one problem should have done it outside fog lights hit the 10ft ceiling part of the way though :doh: xNRJ4Ary7Pk Link to My Channel : https://www.youtube.com/user/littlezeeker1 -
Project Tough Truck
Thank you it did look mean as a dually, and the transfer case spacers were actually made from coil spring spacers I bought from O'Reilly's for like $12 I just drilled the holes a little bit bigger to make my bolt slide through. worked great and almost a full inch drop :wrench: -
Project Tough Truck
Working on the half doors :wrench: -
Project Tough Truck
Going to get alignment done on my jeep :D So after siting so long doing the front end my water pump went out :fs1: -
Project Tough Truck
Did some more work with my paint :banana: -
Project Tough Truck
Well my inner door panel kept coming off so i fixed it with steel and now i don't have to worry about getting it wet either :D -
Project Tough Truck
yes i plan on doing both in time but ran out of money at the time but i hope to really get back to work on it soon :wrench: -
Project Tough Truck
It would but the only problem is it would be about a 14 inch lift up front compared to the 11 inch I have in the back and I don't think much of my stearing components would work that high -
Project Tough Truck
Go to my Youtube Channel I have a lot of Videos on my step by step work and i talk my way though how to do this lift your self for under 800 dollars http://www.youtube.com/user/littlezeeker1?feature=guide -
Project Tough Truck
Still not done but it can roll again still got to make shock mounts and stuff for it -
Project Tough Truck
No ran made a whole rap around the unibody and the bolted and welded to all together to make as strong as i could i use 1/4" steel too -
Project Tough Truck
I never liked how small the Dana 30 front axles were so i beefed mine up a little -
Project Tough Truck
while i was working redone my exhaust went it was easy to get too hard to see it gun metal black on the red block -
Project Tough Truck
Got Started on the Front lift But not Done Yet -
Project Tough Truck
Home Made Transfer case drop kit 1"
