freegdr
Everything posted by freegdr
  1. Why is this necessary ? The 93 to 98 grand cherokee caliper bracket unbolts off axle as do 1989 and down danas on jeeps. Any info on just swapping rotors calipers and brackets ?
  2. pull the ring and pinion carrier bearings and all shims from thre donor housing and install in you mj all should fit
  3. 4.0 xjs did not come with 410 gears
  4. i have found these don't no if they work or not you posted this a long time ago www.gforcechips.com
