pederl
Everything posted by pederl
  1. Did you check the ballast resistor?
  2. My 1989 4.0L Comanche runs REALLY rough, if I bypass the MAP sensor it runs better, I tried a new on and it does the same thing, If the MAP sensor is good, why does it run like crap when it is connected, any ideas??? Thank you.
  3. A 1989 4.0L base Comanche
  4. Has anyone extracted info from the ECM buy shorting terminals 6 and 7?
  5. Sorry, vacuum hoses
  6. Can someone please send or show me a diagram for a 1989 4.0 L Base Comanche. I have some hoses that are not connected. Thank you.
  7. In the 3rd pick you see those yellow connectors, if I connect those to a computer would it be able to tell me anything, or was a 1989 too early?
  8. It is a 1989 4.0 base model.
  9. AC works. The truck is very hard to start, and when it does it runs very rough, I have to give it gas or it dies. If I spray starting fluid into the intake it runs like a champ. I have replaced: Throttle position sensor Idle speed motor Knock sensor Spark plugs, wires, distributor and cap Fuel pump and fuel filter Battery
  10. URL=http://s1178.photobucket.com/albums/x368/shelley67/Aidans%20truck%202010/?action=view&current=jeeppictures002.jpg][/url]
  11. I also cleaned the idle speed motor and the oxygen sensor.
  12. I have replaced the rotor and cap. It is a manual and it starts ok, but it runs really rough.
  13. Question, I have a 1989 4.0, do I have a choke, my engine will start but not very good. New fuel filter, plugs, wires,
  14. Thank you, I will look at it tonight.
  15. Sorry, IAC is what?
  16. Brand new. Any other ideas?
  17. The truck is running but it runs like crap, I have to keep giving it gas or it will die. I have changed the plugs, wires, rotar and cap, fuel pump. I has to be a sensor, correct?
  18. Where can I find a test connector for my 1989 jeep Comanche? I have a Vetronix tester model tech 1A but none of my connectors will fit.
