FigurativeGarbage
Everything posted by FigurativeGarbage
1986 2.5L to 3.4L: Amateur Hour
FigurativeGarbage replied to FigurativeGarbage's topic in Member Projects: Your Comanches
Solved! Pulled the rail to see if any of the injectors were firing. Only 1 fired. I had the injectors cleaned and tested, but roughly 1.5 years ago or so. Rather than pay for another round of cleaning, I bought a remanufactured set. Installed tonight and it ran! Wasn't able to finish the break in as issues arose, but felt good it finally fired. -
Flashhacks seems to have worked for uploading a VATS off bin. Scan 9495 still shows power dropping to 8.5V on cranking. I'll have to check power under load at various points while someone turns the key to start. -
I installed the new gear reduction starter from BMC and it seems to work much better, at least in terms of alignment with the flywheel. Still not firing - still seeing low voltage on cranking. I've tried changing the setting on the VATS bypass, but no change. Sprayed some starter fluid into the air intake and definitely have spark. Got the V6 bin file and downloaded CATS Tuner. My PC reads the PCM, but won't establish a connection for programming a new bin with VATS off. Charged the battery up to 100% to make sure that wasn't causing the issues. I can try using Flashhack. Can recheck the grounds. Open to ideas. -
Battery was fine. Starter was fine per a bench test, but I noticed a mounting ear was cracked. There have been enough issues with the starter binding, needing a lot of shims, and the possible power draw that I'm going to try a different gear reducing starter with matching bolts from British Motors Company. -
Thanks, Gojira. I have some things to work with just from an initial scan tonight. I don't see a VATS issue if I am reading the data correctly. But I do see low battery voltage while cranking (7V to 8.5V per a multimeter and the computer). I'll have O'Reilly's check and charge the battery, then I'll check again. It could be the starter is pulling too much power (misaligned?). There is an injector fault indicator, which might be wiring. I see a MAPS error, but I think that causes the PMC to use a default number and it would still fire. The MAPS connector is damaged, so I'm not very surprised. I have a spare MAPS if it's not the connector. -
Great ideas. Hadn't thought about the safety switch. I still have the VATS attached, just in case I can avoid tuning. I don't have a Camaro ignition cylinder. I've looked at a number of sources and this engine seems very hard to pin down whether it is 30Hz or 50hz. I don't have a reference key to measure resistance. The diagnostic connectors arrive Saturday per FedEx, so I'll just wait and see what the scanner says. Got an adjustable throttle cable from BMC installed yesterday. Crawling towards victory. -
Reviewing my notes, the PCM I ordered years ago was actually for a 94-95 automatic, not a manual. Unclear if that matters, as I gave the seller a manual Camaro VIN for coding. I had the Timers VATS bypass set to 30Hz. I set it to the more common 50Hz. Still nothing. I can try the two other functions on that system, but your comment makes me doubtful it will help. On your suggestion, I've downloaded the Scan9495. I ordered a jumperless ALDL connection and matching wire mount, but it take a week or so for them to ship. Once I see what's happening, I'll see if I need to escalate to deleting the VATS or otherwise tuning. -
Thanks, Coheed. Yes, the noid flashes a bit. Yesterday I found that my PCM ground wires (C1 and C17) were not connected. I got one hiccup. I can still test voltage levels at cranking. I have suspected VATS (by Timers) could be the issue. I recall you ground it to change the Hz, and I am using the default setting. Agree I should get a scanner. -
The fuel pressure tester showed no pressure. Turns out the factory ground wasn't working. I reviewed Cruiser's info on grounding the fuel pump to the frame, but the frame doesn't seem well grounded. As a temporary measure, I ran a long wire a ground in the engine bay. Pump works again; pressure good. I noticed the PCM B+ wire was pulled out of its eyelet. I rewired it and the noid light lit up, but the pulse might have been weak or erratic. I tried to crank the engine again, but it still didn't fire. I checked a sparkplugs and they don't smell like gas. Then I heard a loud "pang" and checked the starter. The drive gear is stuck against the flywheel again. It must have twisted itself out of alignment. A good place to stop for the evening.... -
Oreillys rents both noid and fuel pressure testers for free. -
I had a muffler shop install a custom y pipe and new catalytic converter. I cleaned up some of the wiring with a electrical manual for the Comanche. Finished the cooling system, with the heater core temporarily bypassed. I left the heater hoses long enough that I can reconnect the core later if I want. I also filled and bled the power steering system enough that the pump should be safe to run. I bought a cheap mechanical oil-pressure test kit. After a few short cranks, the gauge came up to about 55-60 PSI. I built a simple 3-inch intake using a Spectre flexible duct. I installed the IAT sensor in one of the rigid couplers. I still need to make the crankcase fresh-air connection from the passenger-side valve cover into the intake, but for purposes of initial startup I am leaving that valve-cover port open. The vacuum system has also been simplified considerably. I am not dealing with EVAP yet. The MAP, fuel-pressure regulator, and PCV system are the only engine-vacuum items I am concerned about for initial startup. I ordered a replacement throttle cable from BMC and installed the firewall guide, but I am missing the original Camaro throttle-cable bracket. Until the bracket from ebay arrives, I can operate the throttle with my hand during the initial break-in. I made my first attempt at breaking in the engine. The engine cranked normally, but no fire. I pulled a plug and confirmed that I have spark. The plug looked dry and did not smell like fuel. I then unplugged one injector and confirmed approximately 12.3 volts at the injector connector with the key in RUN. I tested the PCM controlled ground. It flashed something like 7 volts once while cranking. Tomorrow I'll pick up a rental noid-light set and a fuel-pressure tester (I tested it two months ago, but want to make sure). If fuel pressure is still correct but there is no injector pulse, I have to check wiring/PCM/VATS. -
I installed EFI-rated fuel hose and filter, but still had to build the pump relay and resolve my switched ignition and constant power wiring. I added a 125-amp terminal fuse at the battery feeding a positive bus bar and switched the starter relay wires over. I also installed a ground bus tied directly into the battery ground system. The VATS bypass is connected to the same switched ignition source. I’m using the GM VATS Bypass Module for LS1 and LT1 from Timers. After some troubleshooting with the multimeter, I found a missing PCM ground connection. Once that was corrected, the fuel-pump relay clicked and the pump finally hummed. I rented a fuel-pressure gauge from O’Reilly Auto Parts. It connected easily to the Schrader valve on the fuel rail. The pressure came up into the low-40 PSI range and held. I installed a Dakota Digital pass-through speedometer sensor at the transmission as well. This allows the PCM to receive the electronic vehicle-speed signal while keeping the original mechanical speedometer cable and factory dash functional. -
Seems to have fixed pump/baffle issue. I haven't seen anyone else do this, nor has it been suggested. I hope it works. In the image below, cut the sender guides on the tank wider (at 7 and 11 o'clock). At this orientation, the pump won't press into the baffle wall. I also was able to get the sock on with one hand in the tank. Had to walk away from it twice before I had an aneurysm. -
Looks like I have a common issue: the baffle in the tank is in the way. However, it seems that if you turn the sender just a few degrees to the right, the pump will point straight down and sit in the baffle. This would require doubling the space for the guide tabs, but it seems easier than cutting the baffle (and compromising its function) getting a new tank, bending the sender, or getting a new sender. My hope is the gasket under tension keeps it aligned. It seems no one else has done this in the other threads. Also, the fuel gage is in the way when installing, so I have to partially disassemble the sender and reassemble it with one hand it the tank. I can do this, but getting the sock on the pump with one hand feels like a carnival game. -
Looks like I'll go for the MTS JPSU-6P4.0. Seems like it will provide enough flow and PSI for the 3.4L. https://www.mtscompany.com/sendingunits.htm $39? Its like $65-$160 everywhere else: https://a.co/d/hePOZeq -
Dropped the tank and pulled the sending unit. As I suspected, there's a hole near the rear grommet that is likely the source of water contamination. After I get a new tank, I need a fuel sending unit that will deliver 36-50 PSI to the Camaro engine. I prefer to do it in tank, but I'm not interested in figuring out a complicated custom system. I may do in-line so I can get this fired up this year. I'll need new fuel lines for the pressure in any case. Open to thoughts. -
Spent some time this weekend sorting the original engine bay wiring a bit more. There are still several mystery connections to resolve (hanging outside of the cabin in the pic below). I removed the auxillery lights and relay for now. I also removed the fuel pump and what I think was the B+ latch relays as they look pretty corroded. I ordered a relay box and bus bar to help clean things up. I'll also relocate the electric fan relay the previous owner installed. Frustratingly, I found water in the passenger side cabin. I see in other posts this isn't terribly uncommon and is likely either the hood hinge seal or the blower/heater seal. I'm not wild about pulling the dash right now. Goal is to try and get the motor started soon. -
It has those sections, for sure, but they don't have the illustrative diagrams that I found helpful as an amateur (pinouts, harness routes, etc.). If I'm wrong, let me know what page or upload (if you have have a chance). For example, white, yellow, and green run to the axle and I am guessing they are the 4wd actuator. Identifying these will take some time, but I suspect they are no longer necessary unless they run to the gauges. Points if you know what this is. -
I removed the starter solenoid because the new starter has an attached solenoid. I'm thinking I'll keep the ignition relay. I removed the ICU/distributor (between the original fuses and alternator). The standalone wiring harness is largely thinned save for figuring out the C### connections. I need to clean up the remaining original wiring a bit more (A/C related, I/P to engine connectors, etc.). It is harder to find information on the 2.5L Comanche; the service manuals are not as thorough as the Camaro manuals I've been using for the engine (wiring diagrams for the instruments, headlights, etc.). -
Electrical Manual
FigurativeGarbage replied to BLHTAZ's topic in MJ Tech: DIY Projects and Write-Ups
I can't seem to download this (link is a blank page). Can anyone re-upload it? -
Cleaned up my hand-drawn diagram on Lucidity. I believe I found one solution to this set up: a VSS dual bypass (Dakota Digital SEN-01-4280). This allows the mechanical signal to go to the dash and converts an electronic signal to the ECU. I believe the B28 Buffered Speed Output sends to the dash and therefore can be removed. I'll next make a list of the C100-230 wires that need to be resolved (fuel pump relay, etc) -
I'm currently working on a standalone ECU harness. I’ve de-pinned around 17 wires from the ECU connectors. Most of these were related to automatic trans and AC functions, which are unnecessary for my standalone setup. (not my photo, but used for initial reference) (one of the Camaro manual diagrams) I've been looking at connectors C100, C210, C220, and C230 that connect to lights and the body harness. Example: the C220 alternator connector powers the dash. I have a GM VATS bypass from Timers. I need to figure out speedometer and fuel relay wiring. (The C220 only has two wires in it right now, and matching connector. I'll need to figure out the clutch anticipator.) I also discovered a mystery component with brown and black/white wires that seems to be tied to the oil level sensor area (it has some kind of recessed button that clicks when pressed). The actual oil level sensor connector nearby has two-black-wires. I'll trace the wires back for both if I have to. (Manual reset button? Diagnostics? Kill switch? Jetpack handheld ignition control?) -
I got them from my neighbor. I'm sure you're right. Appreciated, but its okay. The original ones are on now. Mostly an aethetic thing anyways. -
Looking at the clearance, I think modifying the pan was unnecessary. Maybe other the other builds noted the issue had different set ups. See the attached photos; one may appear upside down, but you can see there's a great deal of clearance. In hindsight, I would have installed the engine without a pan and check the clearances after.
