KA88MJ
Everything posted by KA88MJ
  1. Is it possible to swap from an 88 MJ header to the 91+ header? I know the 88 has the extra tube coming off the side, but what else is different, and what kind of issues might one have with the 91+ exhaust manifold on the 88?
  2. When you say you put a new engine and harness in, has the engine ever been ran, prior to putting it in? Have you checked the timing? Will it start if you spray starting fluid in the throttle body?
  3. It never hurts to check the crankshaft position sensor.
  4. KA88MJ
    1JTML6319JT197183
    1988 Jeep MJ 4x4 IJTML6319JT197183 Short Bed 4.0l 5 speed manual- I believe an AX15 Metric Ton- Dana 44 Rear A/C Manual Windows/Locks Located in North Texas. Currently in the process of swapping the engine. Was my dads truck and hasn’t been on the road since 2006.
