novanut1964
Everything posted by novanut1964
1987 Comanche quits running
novanut1964 replied to novanut1964's topic in MJ Tech: Modification and Repairs
no the ecu i got didnt match pins. just touched new coil wire at distributor engine quit, changed coil wire from f350, started but flakey, died a few times, everything is new wiggled every connector didnt die till touched coil wire. new coil new coil module new cap new rotor, new relays, new fuel pump, new fuel filter, new battery, new o2 sensor new map sensor new tps sensor. new spark plugs new plug wires new fusible links new battery cables extra ground cables, extra ground to fuel pump, clean connectors with spray. random shutoff sometimes restart sometimes wait. -
it usually restarts, sometimes it won't wait an hour or next day starts right up. dies while driving and at idle. runs about 20 minutes gets up to 190 temp. cuts out immediately no sputter just dead. -
yes its working, one time i touched the new renix adapter and the engine quit -
i got my comamche from a friend. it was completely in pieces in the front seat and pickup bed. i knew nothing about jeeps, i had liked the 1960's style pickup trucks, i had a tonka replica. the previous jeep blew a rod out the blick amd still drove it, the entire engine bay is oil soaked. the engine was rebuilt with a 1986 block, cast aluminum valve cover, external clutch bell housing, rebuilt ax5 5 speed, no231j transfer case. i shortened and welded the original driveshaft then took it to a shop to be balanced, rewelded and new ujoints. i had to read forums to learn about jeeps, like which speedometer gear and housing i needed to order, i have soent countless hours tobget it running, made 2 100 miles trips to town then it started cutting out driving and idleing very dangerous. each time i merely touched a different component it would shut off, i would order that part, wouldnt fix it. i started doing cruiser54 tips, not all yet, you would not believe how ghis comanche has dominated my free time and limited money, to be unable to drive it is very frustrating. I owned 8 1964 chevy II novas, rebuilt engines swapped engines and can't figure out what is wrong with the comanche, i have ocd amyway, now i truly have the obsessive comanche disorder. -
1987 comanche ignition switch assembly
3rd new cps, new ignition coil and module new relays -
didnt fix issue cuts off every 20 minutes can't drive -
replaced ignition column switch. still cuts off. took computer out again, new 1989 computer pins different. reinstall still cuts off after 20 minutes or so of running. unreliable can't drive. any more advice? only connector i havent cleaned is under brake master cylinder. hard to get at. -
thanks andy in pa, i wanted to know how to reassemble, i forgot if ignition switch goes on first and then the dimmer switch. please let me know inam not certain i didnt take pic before took apart -
i took out the column ignition switch to replace, waited on Rockauto delivery, i can't remember if ign switch bracket goes on first, or the dimmer switch bracket. i finally got it together, now starter won't engage, so will remove again to adjust. need advice to put it back together correctly, thanks
thanks, picking up new ignition switch for steering column tomorow, just replaced fuel pump ran smoother. on 3rd new cps, last one is a Siemens, coil and ignition module are new, within 2 weeks ago. i will update after new part installed. i appreciate any help. alot of time and $, can't drive its too unreliable so far. c101 already bypassed i resoldered the brown ground wires -
new switch -
took ignition switch apart, wasnt burnt, it was corroded, the copper slides had wear marks and some heat discoloration, waiting on mew rockauto seitch -
when the levee breaks, cover by Zepperella, all girl Led Zepplin cover band seen live twice
braided cable to firewall cleaned -
ohms at tps b terminal starts at 18.5 drops to .5 maybe 10 seconds steady dropping. any help appreciated. -
new fusible links, iat sensor was reading high on video i got correct ohm sensor now. just ran extra ground cable from computer ground to negative battery, it ran longer than it has in months. cleaned ground behind taillight also clean/ replaced taillight bulbs. when headlights on right turnsignal indicator lights up a little. tried ohm from tps b ground not sure if reading right -
unplugged all engine connectors, sprayed with electric cleaner -
also new fuel filter replaced. new water temp sensor. watched temperture rise on renix monitor to 190, sometimes 205 if idleing long to test. chd intake bolts, new gasket. -
also 2nd new O2 sensor, unsoldered throttle body lead plug, adjust fuel pressure to 15#, add fuel pressure gauge to tbi port, have new diapragm didnt install as was working, new air filter, new intake air temperature sensor-correct ohms, moved to before tbi hat. vacuum hoses routed best i could dechipher, new pcv valve. 2nd set mew spark plugs engine has less than 300 miles after machine shop rebuilt, retorque rocker arm nuts, some lifter noise, bought newelgin lifters and pushrods after it stays running. new turn signal cam switch in column. if remember anything else i have done i will post it. couldnt get rear tail light cover off to clean ground yet. inside ecm big plug some wires soldered i assume cps wires not sure yet, i ordered an rebuilt 1989 4.0 automatic ecm to try. ordered correct shank cps bolts, on the way. yesterday i grounded positive battery cable to negative 30 seconds started and ran longer than it has in a month. please help i want ti drive it. thanks -
1987 2.5, rebuilt engine. ran 2 days then started dieing while driving. sometimes start up, sometimes wait hours. new map sensor, tps sensor, 3rd new crank position sensor, new battery, new battery cables, new starter, clean grounds, add ground to fuel pump harness, new fuel pump today ran awhile, cut off. new fuel pump relay, clean relay socket, new ignition relay, ran better with old. new coil, new ignition control module, add ground cables block to frame. c101 already bypassed removed 2 crimp connectors-soldered. remove ecm look inside no burnt places, renix engine monitor helps watch, i have touched renix monitor connection engine died, touch tps connector, dies, touch map connector, dies, something different every time i troubleshoot the problem. touch key in column after fuel pump today engine died. wouldnt restart. everything new, any ideas? can't drive. videos search novanut1964 on youtube thanks
