Dragos
Everything posted by Dragos
You are right ! Thanks The car when i found it have the grille mounted upside down. I will check !
91 HO Shut Off While Driving
Dragos replied to kryptronic's topic in MJ Tech: Modification and Repairs
Good day , i had this stupid problem at my 88 Laredo MJ. I have a 4 L Renix. When the engine is hot or driving continuously for30-40 minutes , engine stop. After a 20-40 min break , engine starts. I read all that you describe before and i check all. What i find is that when the engine is not starting I don't have spark. Any way , after 1 moth of looking and changing including ECU , I discover that the problem came from Ignition Control Coil module. I hope that this information will help you . -
Long time , no see! But in this time I work on my Comanche to put back on street! What I've done till now: - Install lift kit of 4,5" - work on brakes rear and front - change cylinder head with one from HO - Change all cooling hose - buy a ne rear bump stop from Westin - refurbished the tail lights - buy chrome parts : mirrors , chrome ornaments - repaint the car - buy beige interior (dashboard, door panels) Any way , i want to swap to 4x4 and I install front axle from an XJ with same gear ratio (change bearings and install long brake hose) I want to install NP 242 donate from an 89 XJ with AV 4 automatic gearbox. I want to mention that I have also AV 4 on my Comanche . I have one question , it is possible to install NP 242 on my AV4 or I need to install on a specific AV4 that became from a car with 4x4 transmission? Some pictures from my car
I have one question : what means: AGL Super Sport Group (SS/T) ?
Thank you , valuable information!
Thank you, Yes indeed, Cruise control , AC, electric windows...
JEEP COMANCHE LAREDO - 1988 - 2WD , automatic - 214000 miles - 4 l Renix - long bed - DANA 44 , 3.54 - Located in Romania - came from Florida in 2005 and is not registered in Romania ; since 2007 the car was abandonate - truck will be restored and registered - next step (after registration) 4WD - Will be painted in black Maseratti - will be lifted 3" and will run 32"x11,5x15 Cooper STT Pro
