EagleEar
Everything posted by EagleEar
questions about my new-to-me MJ in Poland
EagleEar replied to EagleEar's topic in MJ Tech: Modification and Repairs
Thanks for hint , it's seems workable. I will remove wheels check what is really going , one local offroad shop are making service of such repair i will also go with axle there I check what is possible. I also heard that there are some differences with mounts axle - wheel between XJ and MJ. -
Hi Guys, Car is still during painting so I can't show you results yet, but i have problem with rear differential. It seems that driver side axle is little bent , wheel is directed into inside. I planned to change it using xj one but it seems that leaf spring in Mj is mounted down and Xj Up. No Comanche parts are available here , please advise how to solve it in best way. -
Dash connectors - please help
Wow , thanks for quick help , it's amazing. I will buy this delay module for lamps and where is located emission timer ? What about number 3 ? I think there is no similar on other side so this is not speaker . -
Dear Jason, Many thanks for your help , the car is 88 , 2,5 liter , manual. I got 3 of MJ so even signature will not help No 8 was lying on the floor in the middle of cabin. -
1 - Transmission switch Power - will it work on manual ? 5 - instrument planel 6 - cargo light 7 - clock switch Please help with others. -
Hi, Some next steps , rear part of frame is protected now. I used epoxy paint for ships paining so frame is well secured. -
Hello, During replacing the dash i found a few connectors which are not used, please help me with identification of it . Thanks in advance !!! 1. 2. 3. 4. 5 6 7 8
Wow, what a source of info, thanks !!!! -
Hello, I just sending some photos from restoration of 2,5 liter blue one , in black some body works are performed at the moment i will back soon with some update here. Black originally was white, so I would like to remove this raptor like layer and put real white raptor on it. Blue will stay blue , beside originally was black I will back soon with more photos. BTW, there is a lot of connectors under the dash which were not connected and seems there is no place where i can connect them. Does MJ electrical installation is the same no matter of version ? Can somebody could help with wiring or electrical manual ? -
Hi , Old topic but i got some update here which might be helpful for others : Meat and Doria 76972 dimensions : Diameter : 43 mm Intake diameter : 12 mm Intake part length : 23 mm Overall length of metal body with intake : 135 mm JEEP: 52017698, JEEP: 8933063591, BOSCH: 9580810019, FISPA: 20493, FISPA: 70493, HOFFER: 7506972, MEAT & DORIA: 76972, SIDAT: 70493 Oem 2,5 liter pump no. 8933 002 251, model no. 5550: Diameter : 37 mm Intake diameter : 18-19 mm Intake part length : 24 mm metal body with intake : 110 mm In my case where I would like to install it to 2,5 engine is bigger than original one so modifications are necessary. Below I'm adding some photos how it looks like.
Hello , I was out of MJ rebuild because job issues , now I'm coming back and I hope soon I could show you further steps. Please advise if there are available some repair kits / panels to short bed ? Maybe cherokee XJ parts after some modification could be helpful : -
The problem is that guys who are selling car parts are cutting the hinges and not bother to remove the pin and save them. That's why you can find door but not with hinges. -
Hi, It looks that second MJ is comming tommorow a black one, i bought pair of front doors but without hinges. I can't find them here, is there a chance to use from different models or to buy somewhere? -
I have just checked this on youtube , I see that tape for a first time and you are right it will work. Please check the shipment to Poland of driver side lamp and write me on priv with details for payment. -
Do you know when Key parts may release lenses ? Because if this will happen like 1-2 month than its better to buy driver side only in other case I will take a pair . -
If new lenses will be available soon, I could try use 3d scanner and 3d printer to make this black part "lamp body". Than try to make mirror reflection , my printer can handle 25 cm objects only , I will measure old lamp and inform you about the progress. -
But maybe after some body works , i will be able to use it , like some users here. I think I got no choice . Here you go : -
Hi finally I have managed to put those arms, tires fit perfect. Now car is driving and soon i'm starting repair the body damage and paint the car. I will need your help here again, I need to use new taillights those from doge dakota are not available here, can somebody help with buying the pair of it or know the shop with international shipments ? The same with "sport truck" decals on sides . Thanks in advance -
Thanks for advises those solutions above are great !!! I was thinking to do like on movie below : loosen track bar , steering, upper arms , then center all and put in again. If steering is tighten and track bar, can I do force solution ? -
LCA cut like advised , new coil isolators mounted , springs sides exchanged and mounted and I got the problem. Both wheels out, stabilizer disconnected, upper arms are on position and connected (I haven't touch them) , steering rod also connected (not touched) It look like front axle moved on driver side in and passenger out of body and I can't mount LCA it's too short or too long depends of side and shifted out of mounting. How to properly do install procedure in this situation. Bottle jack or something familiar not helping Maybe if i will put wheels again and lay the car on ground , things will return to normal I would be able to mount LCA, please advise - I've already did it now both sides are shifted in cabin direction same on both sides and looks like LCA are to long to mount them . -
You convinced me , I will cut it the same way , thanks !!! -
Thanks for support with shocks , you can see them already mounted on pic above. Now I got questions about rubber bushings which need to be cut , can I buy new one from cherokee , remove old one from LCA of WJ and put it there ? Are those parts are the same ? I will avoid cut which my melt the gum. -
4x4 was planned but some of my friends are telling to keep it as original as possible. I bought also this black one MJ on big wheels maybe this one will be offroad and white will stay and look like old commercials :). I'm little worried about this wheel , axle could be repaired or usually in such cases whole rear differential is replaced ? Oil in tranny is new one i put 10w 30 engine oil like was advised here. Some brake cables where replaced and I need to make new rod for high valve. -
Hi, Little update car is done ,on the wheels and rides, I was riding mainly back an front because wheels are scratching on lower arm, is this the part number which should help - 52088217AB ? The wheel where car took a hit in my opinion is not with the line of front an body and it's directed little inside, is there a good way to check if axles are straight ? Right wheel looks ok. I also noticed that my transmission is BA 10 , Does my enginehousing accept ax-15 ?
