JStone
Everything posted by JStone
  1. I’m sure we’ve all seen the soggy diaper ceiling before, my previous owner decide just to put a pin or 50 in it to hold it Anyone have any cool retro fits or repairs/replace they’ve done? or should I just stick with the colorful pins?
  2. JStone
    1J7FT26E3LL247075
    25 out of Trusty Rusty Salt Lake City
  3. JStone
    1J7FT26E3LL247075
    Thanks guys! Appreciate the insight
  4. JStone
    1J7FT26E3LL247075
    No joke eh? Well that gives me hope, ill have to dive in a ton into the gearing cause I just don't know enough about it. Why is the gearing such an upgrade?
  5. JStone
    1J7FT26E3LL247075
    Too true, I do have lots I would like to try to do with this beaut, including a 2.5 or 3'' lift. I just run into the dilemma of timing and priority. Seeing my brake fluid being that dark threw some red flags so I figured start with the simpler nessecary repairs then move up to the big boy upgrades. Ill probably do a flush of the lines, then check my options. On a less then 3" lift do you have to extend the brake lines? and if I'm going to do this in the future, ( I read a ton about the rear axle swap and the 8.8 being one of the simpler). Do any of you have this done on yours? worth the battle?
  6. JStone
    1J7FT26E3LL247075
    Righteous, will git r dunnn hopefully this weekend 🤘🏽
  7. JStone
    1J7FT26E3LL247075
    You’ve got a good point, hoping some TLC will help the brake lines last a bit longer, I’ll also do some digging into adjusting that equalizer, see if I can snug it up. are those rubber plugs pretty replaceable?
  8. JStone
    1J7FT26E3LL247075
    Eagle Scout. You are the man, thanks for your tips and knowledge I’ll be using them ! I do have a question now! My brake fluid is pretty dark, and my E brakes are not exactly top notch. My rear end looks like it may have a leak, I’ll attach a photo! Do you think it’s worth it do do a disc install on the back? And what kind of headache am I going to give myself?
  9. JStone
    1J7FT26E3LL247075
    1990, Comanche sport truck! 2.5 L ax-4 with I believe the Dana 35 Rwd with 86” wheelbase. really new to this forum! But I’ve got tons to do to her! And I will be around here and there in the club. I couldn’t believe the original warranty guide came with it!
  10. Are the pillar lights and Splash guards for sale? I’ve got a 90 that needs some Pillar lights, some TLC, and some nice new splash guards
  11. Suuuuper good tips!! I’m gonna dive into it tonight and figure out what I need to do to re-pipe that fronter hole ill keep the plastic cover (for now) and change the gasket and see where that gets me. I found a few vacuum diagrams on here. Is your Jeep similar? Like I could reference a picture of yours, no worries either way I can read schematics. New to this forum so I really appreciate the tip!
  12. Just picked up a 1990 Comanche for a guy from a guy from a guy none who had interest in taking real care of it. It was clearly having oil leaking issues but as is such as a mis treated 31 yr old truck. But after the test drive I seen a good amount of oil on top of the valve cover (which is new and hard plastic which I find odd) Drove well from St George to SLC and needed over a full qt on the trip. I just barley ordered a new valve cover gasket and my question is would it be worth it to just change the cover to a full aluminum? And 2 is there possibly an issue with the pcv not pulling vacuum? Causing the oil to come out the side of Valve cover
