MJ4.0
Everything posted by MJ4.0
  1. new lightbar for this plowing season....lol....worth more than the truck.. Image Not Found
  2. got some studs and 1/4" spacers... now its back together again.. :bowdown: studs are from dorman 610-290... E SERIES VAN 2004-75, FORD FULL SIZE TRUCKS 1996-73, MUSTANG 2009-05 Image Not Found Image Not Found
  3. got more done, need some caliper mounting pins and flex hoses... Image Not Found Image Not Found Image Not Found
  4. getting back to it...swapped the knuckles to the wj's... Image Not Found Image Not Found Image Not Found
  5. 33's on exploder rims... Image Not Found Image Not Found
  6. body looks good, uniframe is shot....good parts truck for 150 bucks... :cheers: sry for the dark pics...camera phone... Image Not Found Image Not Found Image Not Found
  7. bought another for parts...pic's once it gets here, had to have a flatbed pick it up, front control arms ripped/rotted out of the frame...
  8. its built for a purpose, just like long arm/coil over guys use their rigs in the rocks... :Canadaflag: :brows:
  9. got my tierod flip inserts... :wrench: another week or two and i'll start the swap...replacing a 4l60e in my uncles truck right now on the weekends as the weather permits... Image Not Found
  10. ok, got my balljoints and tie rods and 1 rotor/hub re-drilled... Image Not Found
  11. ordered more parts....ebays great for deals...lol....100 bucks total shipped....4 ball joints and 4 tie rods... couldn't get 2 balljoints here for that... :cheers:
  12. some reading.... i need to make a set of these spacers and if i flip the tie rods i'll need some inserts spacers- i traced an old knuckle shape and marked the holes for the hub/bearing... now i'll get the tools at work to cut it out... ordered a set of tie rod flip inserts as well... Image Not Found Image Not Found
  13. put the new steering shaft on, deal on a rear 44 from another mj fell apart...found 2 wj's for parts...put my order in for one of the front axles 99 or 2001...just want the knuckles to the calipers....get a good fix for my homebrew hi steer knuckle.. in case you missed the pic's Image Not Found Image Not Found
  14. no luck on a good used lower steering shaft..ordered a new one....cheaper off ebay.... :wrench:
  15. boring day......decided to change my winch controller back to my original...then seen the hole in my cup holder..hmmmm......works for me... can see in the pic, i hated it there in the door.. :cheers: Image Not Found Image Not Found Image Not Found
  16. new headlights, cheap h4 setup from ebay..and a plow wing extension..runs and works well....still waiting for the owner of the d44 to get it out of the scrap mj....should have it by the end of the month, then rebuild and gear it.... Image Not Found
  17. my last fix for now till i get my d44 rear..... with the lift the rear shaft was in maybe 11/2 to 2 inches...to fix it...we went on a hunt.... never forget the extended cabs with a 2 piece shaft... the one i had on was 42 inches eye to eye... the new shaft off a older chevy 1/2 ton.. was 46 and the added bonus was a longer yoke.... so pulled the new shaft apart and played...the new shaft was about 1inch to long, the new yoke was 2 1/2 inches longer than the one i had...and it fixed my driveshaft length for now till the 44 is ready to go in next summer..then i may have to go back to my old yoke cause the 44 has a longer pinion than the 35.... Image Not Found
  18. when mine becomes a full trail only rig...i hope it'll look half as good as this.. liking the f/s axles and the service box setup in the bed... good job...
  19. box/lights/tank all bolted back on... now i'm ready for the snow... Image Not Found Image Not Found Image Not Found Image Not Found
  20. first snow....it worked great...gas tank is straped to a steel plate and straped to the frame till the weekend.. Image Not Found Image Not Found Image Not Found Image Not Found
  21. got more done....but the winch broke...lol...used the cordless.. Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found
  22. long drop brackets for the plow...... :wrench: need to make the setup in red, was cutoff by the other owner :mad: Image Not Found Image Not Found Image Not Found Image Not Found
  23. thanks... axle back in just to make it moveable....needed room to install the new to me woodstove.. Image Not Found Image Not Found Image Not Found
  24. frame is now plated...just need to stiffen the spring hangers.. then put it all back together...its a pain coming home and its dark after 5pm...tow boom may get put on a slower pace and speed up the snowplow install.... :wrench:
