Josephangelo
Josephangelo's Achievements
  1. I have replaced the ccv and the crank case ventilation hose. The oil is clearly leaking out where the filler cap is. The gasket is not sitting perfectly flat so it's not making a good enough seal.
  2. I'm looking for a solution to my valve cover leak. 1988 Comanche 2.5l 2wd base. The problem is the seal on the oil filler cap, I've got a new cap and I even doubled the gasket on the cap. It fits tightly on the valve cover, but it's still not creating a tight enough seal. The only thing I can think of is to replace the valve cover. Any suggestions would be great, thanks.
  3. I'm looking for the molding piece between the grill and the front bumper
  4. I'm looking for a roll pan rear bumper for my 88 comanche.
  5. Thanks for the help everyone
  6. I'm looking for suggestions about gear ratio. I just bought a 1988 Comanche. 4cy, 2wd, manual 5speed. I got 31 inch tires for it. I will be using it as my daily driver on highways and city streets. I will NOT be using it off road. I think the stock gear ratio will not need to be upgraded. I was wondering if anyone had an informed opinion on this. Thanks
