itsjust me
Everything posted by itsjust me
internal slave cylinder question
itsjust me replied to itsjust me's topic in MJ Tech: Modification and Repairs
local jeep dealership told me that they are discontinued. maybe a part number from you guys with factory service manuals? -
both my ba-10 (current) and my ax-15 both have internal slaves. blew up the new one after only a year. i don't really want to deal with converting over to an external slave. can you guys recommend a better replacement? is there a better replacement? I'm not coming up with much....
mj sound like a diesel
itsjust me replied to STERLING STINGER's topic in MJ Tech: Modification and Repairs
mine did that when i got it. everything was gumed up and full of carbine. the ports in my valve cover where completely plugged. something to think about. -
like the title said how much? when i bought my comanche 3 years ago some decent rockers and cab corners came with my truck. they where cut from a to totaled out 2wd and never got installed on my truck. I'm not going to use them and I'm thinking about selling them. i did the magnet test and they seem to be all sheet metal. they need to be cleaned up a little, but they should be good to install. does any one make them anymore? what are they worth? Image Not Found
i ordered a rear axle regear kit (seals, bearings, shims, new crush sleeve, and pinion nut.) around 2 years go. i don't remember if it was for a c-clip dana 35 or non c-clip. i would like to use this to freshen up a non c-clip axle. my question is how much of it crosses over?
looking for a comanche rear dana 35 with 3.55 gears. I'm in grand rapids mi.
Front end still shakes.
itsjust me replied to ftpiercecracker1's topic in MJ Tech: Modification and Repairs
You may want to make sure your front axle u joints are not sloppy or siezed. if they siezed it could be setting them off. good luck. -
so the clutch is the same?
so my 89 comanche sometimes doesn't like to go into gear. it has a ba-10 in it now. i have an ax-15 out of an 89 wrangler. I'm going to be pulling the ba-10 down soon and i would like to put the ax-15 in. i believe both have internal slaves and i know the wrangler transfercase is clocked up more. i would like to know if there is any other parts that will be needed to switch them out.
looking for a pass side chrome power mirror for a 95 cherokee. mine is broken and missing glass. will take one in black. let me know.
i have a wrangler ax15 i got cheap.on the 89 wrangler ax15 the t-case is clocked up more then the cherokee/comanche ax15. can the rear of the trans housing that the t-case mounts on, on a wrangler ax15 be switched with that of a cherokee/comanche ax15?
I'm looking for a used front 3.55 dana 30 hp ring and pinion.
no one can tell me how to i.d. what trans i have? i did a search prior to the first post. didn't see anything to help figure it out.
so how do i tell them apart?
they didn't have a renault option for mine? its a 89 4.0L
couple of questions. 1. i have a hi pinion 30 front and 35 rear axle. they are 3.07s.(at least in the front) the rear tag is long rusted way. i have a 3.55 rear ring and pinion set already. i have noticed some wranglers are off 1(4.10 and 4.11).do the comanches require matching gear sets or are they supposed to be 1 off for the front? 2.how do you i.d. what trans is is under the stick? its a 5 speed. 2.5.can you tell by the shift knob?
local dealership has them $12 a piece.should be all set. thanks.
i think i remember seeing those rubber lines, but no place to attach them. that should help in the search now that i have an idea what I'm looking for. thanks.
