Everything posted by Dickinson County Comanche
1992? XJ I want to use as an axle donor. I think it’s a posi 8.25 w/ 3.55s in the back but I’m not positive about that.
Was helping a friend in North Carolina look for a Grand Cherokee (he has an 80 series Land Cruiser, but was having trouble so I was showing him a good 4WD SUV) and came upon a ZJ being parted out with a set of splash guards, and since I have no self-control, I bought them. I like the way they look, and I also like how it holds on my corner piece of cladding so I no longer have to fix the rust underneath it.
Another yearly/6 month update: I missed a few things on my last update, I installed wing windows and a set of front bumper guards from a 1990 Cherokee, as well as cruise control. Still trying to get it to work properly, but it’s all installed. Looking to try and swap the gears to 3.55s. My 5 speed ZJ has made me spoiled with its 3.55s so I’d like to swap. I have the rear axle already just need a front axle carrier. Been super reliable still, just about to hit 140,000.
Either way, I’ve tried 2 different reservoirs to no avail. Unlike the climate control it won’t have any vacuum at the servo after like a minute or so after you shut it off, indicating to me that it probably has some sort of internal leak, given how the vac line is brand new and has been leak tested multiple times, and the other vac bubble didn’t help.
Jumper wire didn’t fix it. Putting more vacuum to the servo didn’t fix it, putting less vacuum to the servo didn’t fix it. I even took the ground off the servo and it still didn’t fix it (cruise did still work, maybe something wrong there?) but I’m probably just going to get a different servo and see what happens. It’s the only thing I can think of being truly faulty here cause it’s getting good vac, consistent vac, brake pedal isn’t bleeding vac back, 2 different control modules didn’t do anything, and I know the speed sensor is most likely functional given how it will try to hold a constant speed, just it can’t meter itself right so it slows way down then floors it to catch back up, just to immediately pull all throttle out and it slows way down again. I didn’t think it would be this much of a hassle
Ok, so I tested it using plugs and here’s what I found: The larger (Bleed?) hose going to the pedal will hold vaccum. The larger port on the servo side will not hold a vacuum. Both smaller sides, going to the vac bubble and the servo side, hood vacuum just fine. Just to recap, the one with the hose connected (not the same truck but still applies) does not hold a vacuum within the servo itself. The hose does with the pedal switch, however.
Hey all, added cruise to my Comanche and I’ve run into the problem where it wanders in terms of speed. If I set it at 55, it’ll speed up up to 60-65 then slow back down, over and over. It’ll also occasionally sometimes slow down to 50 before taking back off again. I’ve tried adjusting the module screws for about 2 hours and used 2 separate control units to no avail. Also, if anyone has a Comanche with a manual and cruise, I’d like to see how your screws are set to get a baseline of sorts.
I have the rear two, just looking to get the front 2 and whatever brackets (if they even had any) to mount.
