brawndon
Everything posted by brawndon
  1. I have an 89 comanche with 180k miles on it and it was running just fine but the other day while driving the engine just turned off for a second then turned back on and I was able to keep my speed. It then began to happen every other minute and it would cut off for longer periods at a time so I turned around from where I was going to be safe. I have driven it since and the issue had went away but it started back up yesterday. Anyone know what could be wrong?
  2. It is a 2000 xj Sent from my iPad using Tapatalk
  3. Friend of mine is gutting his XJ and my Comanche is an 89 that didn’t come with an AC from the factory. Is it possible to add the AC into the Comanche? I know it’s gonna be a long process to just remove all the parts from the XJ alone. That being said does anyone know if it’s possible and know what I’ll be needing to remove exactly? Sent from my iPhone using Tapatalk
  4. Yes then it’s a crank no start condition. I will take a look at cruisers renix tips thanks! Sent from my iPhone using Tapatalk
  5. Second, cranks no start as engine spins with the starter and engine doesn’t fire up Sent from my iPhone using Tapatalk
  6. When I turn the key to the on position it would crank and not turn over. I have an automatic transmission Sent from my iPhone using Tapatalk
  7. I have an 89 Comanche. It’s kind of my daily and haven’t had any issues with it but couple weeks back I turned it on and it wouldn’t turn over. So I figured the battery is dead so I got a jump and it turned back on but after a few seconds it turned back off. Tried to jump it again and it wouldn’t turn over. The battery is relatively new got it earlier in the year so I figured maybe it’s the alternator or gas problem. I checked the schrader valve and there’s good pressure so I’m not sure what it was. Few hours later I tried to turn it back on and it turned on like nothing even happened. I’ve driven it a handful of times since and the problem hasn’t happened again. Should I be concerned? Sent from my iPhone using Tapatalk
  8. So this summer heat has been killing me and my mj has no ac and I was getting quotes for about 3000 dollars at local shops for installation and I wanted to know if any of y’all have any recommendations Sent from my iPhone using Tapatalk
  9. I’ve been wanting to do some pretty heavy upgrades and don’t really have a price range because it’s something I will be doing with time. The thing is I’m not too sure about brands and what not. I have an 88 Comanche that’s auto and 4wd. Been wanting to get an ax15 to start but again don’t know where to look. Anything is appreciated! Sent from my iPhone using Tapatalk
  10. Any brand recs Sent from my iPhone using Tapatalk
  11. So I have stock brakes on my 89 Comanche with some 33s and the braking is complete garbage. I’m surprised I haven’t rear ended someone yet and I don’t want that day to come. Any upgrade recommendations? Sent from my iPhone using Tapatalk
  12. Okay cool, soooo- I pretty much have a stock 89 mj aside from the lift I have on it. I got 174k miles on it. From what I want... I’m not too sure I just want to have a variety of option. What I do want, don’t know how plausible this is, is to keep it forever hence the engine swap. I have little knowledge but am trying to learn vigorously so I am no longer ignorant. I want to be able to go off road and be able to drive it long distances to national parks. As far as price range I’m up for anything. Don’t plan on dropping lots of money on it since I am a full time student but it will be good to know how much I will be needing in the future so I can start saving. Thanks for your time!
