Jeeps
Everything posted by Jeeps
  1. Ya who am I kidding with the "today's hoses" comment, if anything the quality of parts have degraded with advancements in manufacturing. Better safe than sorry, I'll cut the spring out of the old hose and put it in the new one.
  2. First time I've done a water pump job on the 2.5L (it all went gloriously smoothly, thankfully), and was curious to find the spring inside the lower radiator hose. The replacement hose I purchased from NAPA didn't have a spring. I called them, and the lady wasn't too sure about the necessity of it. She said in general, hoses today are made of better material and don't require the spring that older vehicles once did. According to this guy's video at around 8:25, the spring is supposedly important for ensuring the lower hose doesn't collapse under acceleration. Is this true with today's hoses?
  3. A little update on the Jeep... Fuel pump got plugged and died, replaced that and the filter. New battery / alternator. Took it out camping for the first time, ran great on the way in and handled well off road. On the way home though, a massive coolant leak sprung! Was hitting my fan and spraying all over the engine, dumping out what looked like a liter per second. Fortunate to make it up a hill to the closest oasis with a telephone in a no service area. Coolant finished entirely leaking out within a minute of arriving. Got a tow home and now trying to diagnose what happened... Hoses look ok and when I put water in the radiator, leak immediately starts without running the engine. Appears to be coming out of the bottom of the water pump, so I'm guessing that is what caused the massive leak. Replacing the pump, thermostat, belts, and hoses this weekend. Wish me luck!
  4. Saw your signature and wondered does this apply to 86 MJ too?
    Swap in a relay harness for your headlights before it's too late!!  CLICK HERE!!
    1. Pete M
      Pete M
      all years have the same weird headlight wire harness design. :L:    routes full power right through the headlight switch. :(
    2. Jeeps
      Jeeps
      The cherokees and wagoneers did the same thing. It caused a huge fire risk because of full voltage going through the dash, especially the ammeter is responsible for many a burnt down wagoneers/cherokees.
  5. +1, would like to know the details and cost of a simple paint job. What was that process like? The transformation turned out amazing!
  6. Well, I'm already married to my 79 Cherokee. Replaced every damn part in this thing but the frame, body, and axles since 2014: But I do think I'd like to treat this Comanche with some TLC. Feel like the body is nice enough that it deserves to be a bit restored and refreshed, I might bang out a couple of the small dents and give it a paint job someday, but like a cheap paint job that won't mind sage brush pin stripes added to it.
  7. Beginning a new project on this MJ. Always wanted one, this just popped up yesterday on the local craigslist for $1,800 and I jumped on it. Used as a work truck by the previous owner. Came with a spare battery and a couple of tools in the bed, huzzah! A junkyard 2.5L was swapped in after the previous engine blew, this one is allegedly at 200k Question on this setup here... What is with this green wire that goes down to the starter solenoid? Also all that taped up wiring going to the ignition coil makes me a bit nervous, should probably replace that. Other concerning wiring.. what's this severed huge gauge red wire to nowhere coming out of the firewall next to the blower motor? Yikes! Haha. I haven't fully devised plans for this Jeep yet as it was a sudden find yesterday. But the tires are new and I like the wheels, and it's in generally running condition. I think for now I'll just be putting some basic maintenance like care to the hood release mechanism and various projects / recommendations from the "what is the most important tip you'd share with new mj owners" thread. Maybe once the tires wear down and it's time for new ones I'll think about a small lift for this truck. It will mainly just be used for in town driving as a body double for my 1979 Jeep Cherokee Golden Eagle during the winter. I've fully restored that old girl over the past few years with a new AMC360 and is my main rig for adventuring. But I'll still occasionally take the MJ out on mild trails and camping trips that would benefit from a little lift and larger tires. Perhaps if I stumble across a 4.0L I'll drop one of those in. I've owned a couple 90s Cherokees and have always loved the 4.0L. I'm all ears for recommendations of improvements and upgrades I should think about making to this MJ!
