reevesmanche87
Everything posted by reevesmanche87
  1. For those who have a 4.0 stroker in their builds, do any of yall run an aftermarket ECU or did you get the stock one refreshed? I'm doing a 4.0 HO swap into my 86 after I build the motor and want to know the best way to do this correctly
  2. is anyone running a fuel cell on their MJ's? I'd like to see some setups and would like some advice, I'm thinking about getting rid of the stock tank and running a fuel cell
  3. What is fitment like for older dodge Dakota tail lights on the comanche? I've seen some things about it but I'm not really getting a clear picture as to what it's like
  4. Been reading mixed things about spring over and spring under axles and was hoping to have some questions answered here. Going from spring under to spring over, does it increase ride height? What are some benefits of going to spring over?
  5. Hey all, been doing a 96 4.0 HO swap into my 87 comanche. Been doing all my research and everything to make sure I do it right. Just wanted to know one thing, should I swap the break booster and everything from the 96 to the 87?
  6. no clue how many gallons my tank is, I'm going to make a guess and say it's 16 gallons. where would you recommend I get the Carter P90011 kit?
  7. I'm trying to find a fuel pump for my comanche because I am putting a 4.0 in it. Can I buy a sending unit and replace the one in my truck currently or would I need to buy a new housing and assembly as well as a pump or is there some sort of alternative?
  8. noted, thank you
  9. i've been looking everywhere or one that isn't new preferably right now bc i'm on a bit of a budget. apparently here in central florida they are just about non existent
  10. since the ax-15 manual transmission is so hard to find, what are some compatible 5 speed manuals for the 4.0 ho engine?
  11. No idea what the gear ratio is, I've just now started to do modifications and upgrades. What are leaf perches and are there adapters to add to the rear shaft or will I need to get a new one?
  12. Am I able to use a Cherokee drive shaft and axles on a Comanche? I'm doing an engine and transmission swap for my Comanche going from the 2.5 l manual trans to the 4.0 auto trans
  13. I'm at a bit of a loss. My comanche keeps draining the battery and I have no idea what could possibly be draining it. I figured it was the radio fuse or the dome light fuse so I took those out but it didn't seem to help. Is there anything I could possibly be missing that could be draining my battery?
  14. the recipient is a, 86 comanche 2.5l 4cyl and the donor I plan to get a 97+ 4.0l cherokee
  15. when doing an engine swap, would I be able to salvage the wiring harness from the donor vehicle? if not, does anyone know where I would be able to buy one?
  16. not to my knowledge
  17. I'm not sure. I don't think it's the relay because I'm not getting power anywhere in the jeep. should have made that a little more clear lol
  18. just recently rebuilt the TBI on my 87 2.5l comanche and when I went to crank it, I wasnt getting any power. I know the battery is good because I took it from my daily and both terminals were properly tight. anyone know what my problem could be?
  19. How easy would it be to go from a 2.5l to a 4.0 il6 in my comanche?
  20. I forgot to add that it still has the bell housing and everything for the 4.3 and everything runs and works except the 4wd.
  21. I've recently come in possession of a Chevy s-10 Blazer with a 4.3 L engine and I was wondering if there is anyone on here who has done a swap or knows someone who has swapped their engine with something similar or with the same engine
  22. I was once told that I could use Dodge Dakota tail light covers on my comanche. Does anyone know if they would fit or if I would have to find tail light covers for a comanche?
  23. I'm removing it so I can clean it. when I got the truck, it was in terrible condition and barely ran but since then I've gotten it to where it will run decently but not good enough.
  24. it's the 2.5L 4cyl, my bad I meant to mention that.
