Jpooley
    Orem, UT
Jpooley's Achievements
  1. I want to tell you that this post saved me! Thank you! I’ve been fighting with low psi for the last week and could not figure it out!! I pulled the pump assembly and low and behold, that same 1/4” hose was loose. I tightened it up, put everything back together, and now I’ve got perfect psi! 31 and 39 when I pull the vacuum off. Hallelujah!
  2. Thanks Pete. I’ll check them out.
  3. Hey everyone! My current project is putting the combination of a 4.0, ax15-ba10/5, np231from an ‘88 long bed into an ‘89 short bed. The shorty was originally 2.5, ax5-ax4, 2wd so neither of the rear driveshafts are the right length for my current setup. I now need the swb, 4.0, ax15-ba10/5, np231, d35 length. I believe it’s 43.25” according to the table above. Can someone confirm this and does anyone have suggestions of where the best place to get one would be? Thanks!
