ok, I havent really had time to address this situation yet. AND i don't have access to the proper gauges or a multimeter at this time. (guess i may just have to bite the bullet and buy one)
I did however, get to take it out for about 50 miles round trip, and it seemed to do ok (except for when i would have to stop, then the oil pressure light would come on). The truck wouldnt shut off if i threw it up in neutral OR when i just GRADUALLY came to a super slow stop. it would kinda stumble a little and idle rough.
Can i adjust my 2.5 TPS in the same manner as the 4.0s (i know there is a thread for this, but from what i can tell its for the I6)?
My throttle is actually resting on my ISA, from what i have read, this is NOT correct. and it seems that if the throttle was moved just enough to get it off of the ISA that it would solve the low idle problem (right?) but the "adjustment screw" is dang near impossible to get at to adjust (esp. when motor is hot.) My dad said that it seemed like it could be a timing issue, but the timing is not adjustable, right? he suggested rotating the distributor assembly ever so slightly and see how it acts.
There is also a noise around the mid to upper RPM range (sounds like something with a bad bearing, i have no idea what an actual bad bearing sounds like in a motor, but you get the idea) You can hear it when in park and rev the motor or when you are cruising along without any real load on the motor. just seems to be in a certain rpm range. any ideas?
I have been told to just drive the d@#m thing, but for some reason i feel like i have to baby it. And that SUCKS!!!!!! lol I'm learning as i go and i just don't want to do any damage.
