Everything posted by Moffat007
Huck731 - did you find one to buy ? I'm thinking of parting with my '89 2.5 2WD if you are still interested. It is in good running condition. Let me know, I can post more pics if you want
She has about 220 000 on the clock. But running smooth - no hesitation, no misses , very responsive. Sent from my iPhone using Tapatalk
Hey everyone, finally got the 4 cylinder running. Installed new cat, muffler. Unfortunately did not pass smog. In fact The tester could not give me a report but told me that it’s polluting because it’s too overly rich. Could not get an accurate reading . I agree that it is rich. But where do I start ? In the resurrecting effort I replaced the following- O2 MAP Temp Vacuum pipes Fuel pump and assembly ICM CPS I don’t want to drive it to spare the Cat. Can it be the EGR that is causing this ? Or the Fuel pressure regulator? Manifold ? Carbon build up in the combustion chamber I spent a lot of $ and time already [emoji85] James Sent from my iPhone using Tapatalk
Electrical or fuel problem?
Moffat007 replied to Moffat007's topic in MJ Tech: Modification and Repairs
That one on the side wàs the coolant temp sensor when I screwed it out, coolant leaked out. Sent from my iPhone using Tapatalk -
Big thanks to everyone, problem solved . I replaced all the sensors mentioned above - but the problem was the autozone fuel pump all along - I bought a new one from NAPA and now she’s running like a champ ! Sent from my iPhone using Tapatalk -
So mine has two - I guess one for the gauge and one for the comp? Sent from my iPhone using Tapatalk -
Ok got it - can you please guide me to the temp sensor? Is it the one on top or on the side of the manifold? -
So the O2 sensor did not fix the problem. I’m down to the fuel pump and fuel regular. I did ground the fuel pump properly per the directions in another topic post. I will check and secure the wiring going into the tank to the pump. ( pump is new...) I’ll also be adding additional grounds per the above mentioned tip. -
Thank you guys ! I’m installing the new O2 toady Sent from my iPhone using Tapatalk -
... O2 sensor A and C... Sent from my iPhone using Tapatalk -
Do I test the sensor while idling or just with ignition on ? Sent from my iPhone using Tapatalk -
Thanks for that I’ll give that a try. To answer the other question- pump is new Sent from my iPhone using Tapatalk -
Injector is brand new Sent from my iPhone using Tapatalk -
When MAP is unplugged, she’ll start but then immediately shuts off. When plugged in . She’ll idle forever BUT Sent from my iPhone using Tapatalk -
TPS is functional from what I can tell Sent from my iPhone using Tapatalk -
I forgot to mention, it only happens like 5 mins after starting- as if something warms up and stops working .... if I drive immediately after start it doesn’t happen and I can get full RPMs . Then all of a sudden it would not let me touch the gas Sent from my iPhone using Tapatalk -
Can this be a Electrical issue, like a grounding issue ? Sent from my iPhone using Tapatalk -
Hey people, I’ve been struggling to get my 89 2.5 Comanche to run. She starts and idle well , but as soon as I step on the gas peddle she halts. The moment I let go of the gas she goes back to normal idling. I’ve replaced the CPS, Ignition Module, vacuum hoses and still no change - it’s sounds like she’s smothered either too much gas or to little gas. I’m ready to give up . Please help ! Sent from my iPhone using Tapatalk
