Jeff J
Jeff J's Achievements
  1. This is a little bit of an old thread that I found a couple years ago. Moving the wire on the pot does make the gauge work in the correct direction. Accuracy is an issue. My gauge would show empty while still having a considerable amount of fuel. I can't remember if the arm is long enough on my sender or not. Still better than working in the wrong direction since I don't drive my Comanche very often. Now I have to switch the wires back the other way since I'm installing a gauge package with a mechanical speedometer so it will finally work.
  2. Thanks, thanks, thanks....
  3. Interesting, that shoots my theory down.
  4. No problem. I've got one set coming now. I wonder since they changed the speedometer attachment in 87. Were the clusters white in 85 and 86 then blue 87, 88, 89 and 90?
  5. Interested in selling the plugs you cut from the harness?
