Kjell
Everything posted by Kjell
  1. Replaced the other brakeline ( bypass line)to rear brakes , getting to be an expert on bleeding mj brakes
  2. Found a box that lay on a shelf for a while ...1989
  3. Yes! Must be a good primer! maybe i finish the job after... 30years
  4. Was it early monday or late friday when the painting was done
  5. At last I got rid of those ugly turn signal lamps converted the reverse light to turnsignals whit orange bulbs and new licensplate whit better dimensions! Rear step bumper from a 07 Nissan Navara
  6. Diesel rabbit .. about 60hk something? White lightning! I had 4 Rabbits last week one gti -83 two cl -84 -91 and one pick-up -92 horsepower from 75 to 138 all whit gasoline engins , now they are sold to finance the Jeep Comanche adventure Vanagon think they called Caravelle here . fill the tank up at KFC i read about someone who drove on vegitable oil here in Sweden worked fine in the summer but in winter they had to have a 20 meter heating cable in the tank
  7. The nice Flag came whit the car
  8. Old one,dust and rust
  9. Close enough... rear step bumper from a Nissan Navara 07 may adjust a bit better when there is time
  10. After the last minute adjustments with brakes before inspection and test run we are back on the roads Testdrive_Medelstor.mp4
  11. Old faithful did not work so hard the last 10 years , transporting tools/ cainsaw on weekends 1992 modell Golf Caddy (Rabbit Pickup US)built in Sarajevo Bosnia
  12. Swedich Laws ... and quick fix by importer have to do something about it maybe combo reverslight / orange bulb for turnsignal or skip the reverslight......
  13. This is what the comanche replaces ,are there any left in in USA ?
  14. Ok, thats nice Gjeep . did notice the striping but i belived it was put on the car by some pre owner not original hmmm striping on the hood is i bad shape have to consider doing somthing better then removing it then . Did some work whit the brakes today and had to make some new brake lines/pipes .Had a pair of used Cherokee discs but they did not fit so the original discs have to run some more miles Was angry over the gastank/ frame /rear weelhouse? solution what a dirttrap, have to do something about it fuelcell? weld in stainless steel? tomorow ill attac the master cylinder looks like it been leaking for some years.. . ok ... kilroy was here before me is this the correctly installed spring ? dident look this way on the other side but i installed like this.
  15. Hi Coolwind rock n roll and Indy 500 nope, theres no Metric Ton emblem but a Dealer emblem . Guess the tax rules roadtax and drivinglicens rules" laws" here in Sweden is behinde that ,i belive most of the Comanches have a max load off 700-800 kg in registration papers. This is only a paper product and not what the cars/trucks was built to carry, all types of Comanches got about the same max load. Maby theres a bunch of Metric Tons emblems in some old warehouse that the importer company owned here in Sweden . The importer also put on some real ugly turnsignasl extra lamps in back of the truck (rules are orange turnsignal if the car is newer then about 1970) And licens plate is to big so its scratching the tailgate I'll take a pic of it tomorrow Did get the brake parts i need today att the local carparts shop they had all parts in stock accept the parkingbrake wires THANK YOU Cherokee 33 ℉ in my open blue sky garage need to fix front brakes and get inside before it start snowing
  16. Hmm the white tooper is remowed, before fixing the brakes " appearance before funktion/safety" Very common whit those toppers on pickups and small trailers here in Sweden , especially in the winter due to wet frozen tools whit rust on them. I'll keep it in storages takes 5 minutes to put it on when needed Nice profile pic you got there Bluenotenick "we are Motörhead and we play ROCK N ROLL" Rubber , plastic tubes electrical connections Pete , had to replace some going over the fuel injection . looooong hiatus, had to goggle that Lazy copy/paste ? Usally its the rust thats the big problem around here ,but looks like it can be saved. Thats before looking under the carpet The plan is to keep it running and do a restoration bit by bit. Great forum/club you are doing a fantastic job THANKS!
  17. Hi ya' all was crusing the ads for a 4 wd ....and found this 1988 Comanche Laredo Metric ton 4,0 automatic floor gear . working on brakes right now to get it streetlegal . Last time it was out on the roads was back in 2001
