Peterjojo
Everything posted by Peterjojo
Hey everyone. I believe I totaled my 1987 L6 Comanche today. It looks like only the radiator and fan are destroyed but the front end structurally may be very messed up. I loved this truck. I just don’t think there will be any way I can afford to fix it. But before this it was in great condition. It only has 116000 miles on it. these trucks are becoming so rare that I would hate to just send it to the junk yard. Does anyone have any recommendations on what I should do?
Hi everyone I’m back with questions. I have an 87 L6 manual. the parking brake won’t catch anymore. I’m assuming the teeth on the catch are worn down. does someone make that part? Or has anyone else dealt with this? thanks
I didn’t see the 87 manual on the site. I thought it changed after 88
Which manual works for the 87 L6
Do you have any manuals you’d recommend?
I replaced the starter. All good. my old one is caked with old old oil nothing fresh. I will be honest I’m not really an experienced car mechanic. I’m a carpenter. I’m smart and handy. But if this hadn’t worked I would not have known what to do. thanks for responding to my question everyone.
Yes. I’m in neutral. Thanks for getting back to me so fast.
Hi everyone. I’ve seen a few threads on here about starters, but wasn’t seeing one that answered my question. I apologize if I missed one. I have a 1987 6 cylinder manual transmission for the last few weeks every once in awhile when I go to turn it on it has a very hard time turning over and sounds like the battery is almost dead. But it’s not and it will start right up on the next try. Although it has been taking longer for it to fire up. tonight I went out to start it and it kind of turned over but didn’t start and the next time I turned the key there was nothing. No clicking. Not even a slight turn over. I open the door and listened and when I turn the key there is a whirring sound but that’s it. Does this sound like it’s likely the starter? that’s what I would guess but wanted to see if anyone else has experienced this. thanks.
Hey. I just saw this. Yeah. How much would you want for one of the units? Thanks man.
T connector wiring harness for trailer
Peterjojo posted a topic in MJ Tech: Modification and Repairs
Does anyone have any idea where to get a wiring harness? I found this one. It says it won’t work but the connectors look the same. -
I’m looking for a complete factory AC assembly for my 1987 6 speed.
Yeah. I was talking to my Jeep guru yesterday about replacing the thermostat housing with one that has the extra hole to install an after market temp gauge. But man it’s so hard to tell if what I’m looking at is actually going to fit my 87. Getting parts it becoming very hard. The Cherokee from that 86-90 era are the same though right?
adding AC to a non AC truck
Peterjojo replied to ICEBOX's topic in MJ Tech: Modification and Repairs
Comanche chief. I love that you’re doing this as I’m about to do the same thing and I like that you’re doing it in 2019. As opposed to 2011. When this thread began. Where have you sourced your parts? -
Here’s kind of a stupid question. I’m concerned that my overheat warning light isn’t functioning and it’s getting hot. Does anyone know how to check this?
Yes. I’m just about to put an AC unit in my 87 that never had it and want all the info I can get. Thanks.
i got into an accident the other day while it was raining. The car in front of me stopped suddenly and I jammed on the brakes and avoided the car but hit the curb with my wheels turned all the way left. So the rim hit the curb basically flat against it. That bent the rim. But I took it to an alignment place and they said they thought something is bent in the steering gear box because amazingly my alignment is fine but my steering wheel is off center to the left about 20°.
Oh really? I was looking through my chiltons manual. And it said the engine needed to be moved for part of the suspension. The upper sway bar I think.
Thanks. Yeah. I’ve been doing a lot of research this morning. I need to replace the suspension in the front and the steering gearbox. I was hoping I might be able to do it on my own but from my research it involves moving the engine which puts it outside of my capabilities. I was kind of hoping to find a database of Jeep mechanics in my area.
I will need to pay a shop. Unless it’s something that could be done by a novice.
all that plus the gear box not the brakes.
Does anyone have any idea how much it would cost to rebuild the front end of my Comanche. It’s 2wd standard trans
This is an old thread. Does anyone have any updates on this? I looked into buying a kit from ready made air in Texas but it’s like 1200$. I have an 87 Comanche that I love but the lack of AC is killing me.
