dmatt5656
Everything posted by dmatt5656
  1. Okay so...a little update found a couple of intake blots loose so I tightened those up. Now it is idling low. Sent from my moto g(6) using Tapatalk
  2. Sorry it's a 1990 4.0 manual Sent from my moto g(6) using Tapatalk
  3. Okay so I'm idling around 1200 rpms. I've replaced my tps cps map sensors. I readjusted the tps today and I'm still idling high. I can't find any vacuum leaks with my starter fluid and I've gone through and done the first 5 steps on cruiser 54's website. I am no expert. This has been an on going issue and quite frankly I'm at my wit's end. Sent from my moto g(6) using Tapatalk
  4. My 1990 Jeep Comanche has a leaky water pump what's the best water pump to use? Its a daily driver Sent from my moto g(6) using Tapatalk
  5. So I had to fix my loose steering column before I could dive into my ignition switch because it needs to be in acc to replace it if I'm reading the directions correctly. Well I can't turn it back to ACCbecause of the trim around the column is being pushed back by the peice that actuates back when the key is turned. Idk what it's called it's got teeth on i left side of the column Sent from my moto g(6) using Tapatalk
  6. Okay thanks man I appreciate it Sent from my moto g(6) using Tapatalk
  7. So everything works on ACC. I got my brake lights back. I put a new ground in the driver's side tail light. Still no heat turn signals radio or wipers Sent from my moto g(6) using Tapatalk
  8. Horn is missing the spring to make it work but it used to function. I lost the spring and just haven't fixed it yet. And to be honest I hadn't thought about checking if they work on ACC Sent from my moto g(6) using Tapatalk
  9. Yes it runs fine. No bad fuse. And it's a manual Sent from my moto g(6) using Tapatalk
  10. Sorry man I'm at work. Like I said. Bear with me. It's a 1990 4.0 Sent from my moto g(6) using Tapatalk
  11. Okay so I'm kinda in a hurry so please bear with me. On my way into work this morning my comanche was running normal and everything was working. I shut it down to go into the store. When I came back out and started it up only my headlights dash lights ashtray light and dome lights were working. My heater, turn signals, radio and wipers suddenly weren't working anymore. Idk what the problem is. Please help winter is coming and I don't fancy freezing my boys off Sent from my moto g(6) using Tapatalk
  12. Thank you. I wouldn't mind some pictures of this at all ha. Sent from my Z982 using Tapatalk
  13. Okay so I have a 1990 jeep Comanche Elminator 4.0 it's my daily. I also have a 2000 Cherokee donor. My problem is the valve cover on my Comanche is leaking and not around the gasket. And today I discovered that my oil cap seems to have disappeared. So my question is Will the valve cover from the 2000 fit on my 1990? Sent from my Z982 using Tapatalk
  14. I am wanting to get rid of my unnecessary vaccum lines and replace with something a bit more durable. Silicone? I don't know I haven't been able to find anything on this. Sent from my Z982 using Tapatalk
  15. Delphi Sent from my LGMP450 using Tapatalk
  16. I do have a question though. My fuel pump has been whining since it was installed. Is there any way to stop this? Sent from my LGMP450 using Tapatalk
  17. Mine currently reads backwards. Its pretty accurate though Sent from my LGMP450 using Tapatalk
