88 mj 4.0 aw4 4x4. Did upgrade injectors new timing set, oil pan, rear main seal, water pump along Iac, Tps, coolant temp sensor, plugs,wires,cap,rotor, Upgrade factory computer to run renix system better. Also fuel pump is original to my knowledge with a new fuel filter if that helps at all. The truck has an eratic idle. It seems to respond well when I blip the throttle. What I notice is the engine comes back down after the rev back to an idle and it seems to drop sudden. Then it catches itself and picks back up in rpm. If I don't touch the pedal it sits and idles. Just isn't smooth has like a roughness to it or like a miss.
Any help with this would be greatly appreciated! I will do my best to do the tests you guys suggest and report back. I just need someone that knows these alittle better that can help me out on this project of mine.
