jeepman 87
Everything posted by jeepman 87
  1. I checked all fuses. The web said it could be my light switch going bad and not letting enough curent to go through it. Is this possible
  2. Now I have no lights inside my mj no dash, shifter, heater controls and my clock goes out when I turn on lights. Also my rear passenger driving lights don't work but stop lights, turn signals all work ( I did just put in a new red top optima battery in ) :dunno:
  3. On my 89 mj the a/c compressor is bad can I put a newer compressor from a 97 to 01 xj compressor on it or will I have to buy a stock one ?
  4. On my 99 xj when you have the a/c on or the defrost on why does the electric fan and a/c compressor kick on every 5 to 10 seconds? ( could it be the hi low switch? )
  5. Just a wonder why my passenger side rear tail lights went out and won't work :dunno:
  6. Nope had a long bed 86 traded for 87 long bed now it's a parts truck for my 89
  7. How about just the top part of dash just around cluster
  8. How hard or what are the steps to take the dash out
  9. jeepman 87
    Cruise
    Not much just the wires were cut and pulled out from the turn signal switch, so I was just wondering so I could replace switch thanks
  10. jeepman 87
    Cruise
    Did the 89 eliminator come with cruise control
  11. jeepman 87
    Lights
    Would the interior lights out of a commander work in our Comanches
  12. jeepman 87
    Latches
    Just to know if they will swap from door to door, my front door latch doesn't work and I have a 99 cherokee back door ( front door is a 97 )
  13. jeepman 87
    Latches
    Anybody
  14. jeepman 87
    Latches
    Are the front and rear door latches from a 97 to 01 Cherokee the same
  15. Door took out fender when I opened it all the way
  16. Sorry it's a 89 eliminator short bed and thanks for info. Went to dungeon and found out my hinges were bent out some, but also my latch is shot, so now I have to order a latch and new fender and hope it all works. Then she is going to the shop to get new rockers and floor boards then sanded and painted
  17. I have a 98 mj and put 99 Cherokee doors on it, they fit fine but the pass door was bad so I got a 97 Cherokee pass door and it doesn't fit, big gap by cab corner side and now hits fender, I put another shim on top and bottom but won't shut, I really just want to know if different year doors are shorter or longer or what can I do :dunno:
  18. jeepman 87
    Door panels
    I really need 97 to 01 manual window door panels to finish my mj I can't find any around and just ordered manual regulators ( please ) :bowdown:
  19. jeepman 87
    Low
    Went to lkq near were I live ( hated it never again ) they didn't even have one Cherokee. So my wife and I went down the street to another jy and scored, they had 3 Comanches, found a headliner backing pad, a 97 Cherokee door, and a bunch of little nick nacks for less tan 200 bucks :clapping:
  20. jeepman 87
    Door panels
    Would like to buy the door panels from a 97+ Cherokee 4-door would like dark grey but doesn't really matter, but I need the manual windows and no other power Thanks
  21. Could someone Please give me the web sight for the guy who makes headliners ( the one that has the backer board and everything Thanks
  22. jeepman 87
    Cooling
    Really need a fan shroud for my 89 eliminator
  23. Will a 97+ shifter nob work
  24. How does the nob come off on a floor mounted auto shifter
  25. Are 4x4 stock coil springs taller than 2wd stock coil springs, and also when I put a 4wd axle under my 2wd can I use the old control arms or do I need the ones from the 4wd donor
