kill_burst
Everything posted by kill_burst
Door hinge pins replacement
kill_burst replied to kill_burst's topic in MJ Tech: Modification and Repairs
Great info. So no need to replace bushing? Just go with the 1/4 inch bolt. -
I have some serious SSG on my drivers side door. Want to make them half doors and figure I might as well fix the pins and bushings while I’m at it. I believe the bushing wore out and that’s what’s causing my issue. Anyone have any luck finding the correct pins? Seems like all I can find are the 97+ pins. Any help would be appreciated.
I recently installed a bedside exhaust. Everything came out looking good. I originally had the exhaust tip facing the wrong direction which caused some issues when driving about 40mphs. I’m guessing some major back pressure. I fixed the exhaust tip and the motor is much smoother now at higher speeds. However I still get some minor vibration when I reach around 55 mph and cruise for about 5 minutes. Before new exhaust it had never vibrates like this. Running a magnaflow glass pack, no cat. Any ideas what this might be? Still getting minor back pressure? Thank in advance
Tail light assistance.
Thank you and yes they are home made. -
Back if the tail lights has 3 wired white for ground, black says tail and red says stop and turn. The turn signal I was able to get through my amber light on the bottom. Just struggling to get the darn brake and running lights figured out -
The back has 3 wires. White for ground, and a red and a black wire. I will have to pull them back off real quick to see what they say as far the red and black. Wonder if if I need a converter or find the correct lights lol. Never been much for wiring. -
Hey gang. Could use some help with these tail lights. Made some new ones because I ripped out the old ones on the trail. I believe I figured out turn signal and also running lights. However I am struggling with getting brake lights and running lights with brake lights. I have turn signal going to the amber colored light and trying to use the red light for brake and running. Any help would be appreciated. Also a link or pic of the wiring diagram could also be helpful. Thanks in advance.
Factory xj rockers same as Comanche?
kill_burst replied to 1989 comanche mj's topic in MJ Tech: Modification and Repairs
Very true, this is why I am replacing mine with 2x4 rock slider -
My drivers side door latch is literally falling off. Anyone felt with this and if so, what steps did you take to fix it. I don’t want to just start cutting stuff before what some of you have done. Thanks in advance
High Crank Case pressure/oil leak
Good to know. Thank you -
Awesome. Thanks for the info -
I actually just pulled off the rear line as you mentioned. Zero ail is getting through that line. It was completely clogged up. Hopefully that’s some of the issue. -
So I have been slowing building worn out 90 2wd Comanche into a 4wd mild off road build. I finished the conversion and replaced most everything. Took her on her first trip which was a 6 hour drive to Kentucky, 3 days of trails and a 6 hour drive home. She did pretty well however I started to loose oil very quickly. All the oil seemed to be coming from the drivers side under the air box. I finally got home and pulled the air box out. There is pooled up oil in the air box and the air filter is completely saturated. Will try the cruiser vavle cover mod. Any other reasons I will have High crank case pressure? Thanks in advance.
Great tip. Thank you
I have a chance to get a decent deal on the small ARB air compressor. I know it’s not really meant to inflate tires, mainly designed for the ARB lockers. However, would adding in an external tank allow me to use the small compressor for airing up tires (33s). Thanks in advanced.
Needing some help. My gauge reads past full and will stay that way. However, at random times it will read 3/4, 1/2, and even 1/4 full. However once I shut off the truck and it sits, it will read past full again.I have checked grounds (including the one behind the tail light) and the connection at the pump and they are all good. Any help with other steps I can take to get this old gauge working again? Thanks in advance.
I like it. Thanks!
So I have been to Napa 2 times and was given the wrong part twice. I did a 4x4 swap on my 90 MJ and I need a longer cable. My cable has the plastic end that snaps in the speedometer. They keep giving me the metal one that screws in. Did they make a plastic cap speedometer cable for 4x4?
Will do. wasn't to excited about the idea of welding it.
I am running a Rubicon Express 3.5 inch lift. I have been having issues with the stock track bar bracket working itself loose over time. Is it ok to weld portions of the track bar to the frame or has anyone had success with other options. Thanks in advance.
I Actually have the original seat still. the fabric is toast however I should be able to take the springs off of it. Not sure why I kept it but now I'm glad I did lol. thanks!
I have a bench seat that is in great condition. However, the drivers seat foam is not as supportive as it once was. Anyone have and tips on improving the firmness? Adding foam possibly? Thanks
