Everything posted by WolverineCub
Looking for a Rear Window Seal
WolverineCub replied to WolverineCub's topic in MJ Tech: Modification and Repairs
Thanks Guys, I know it is for looks, I decided to go with the: CRL Duo-Vent Four Panel Sliders for 1986-1992 Jeep Comanche Steve -
Has anyone ever installed this Rear Window Replacement? CRL Duo-Vent Four Panel Sliders for 1986-1992 Jeep Comanche -
Hey All, Looking for a new rear window seal, part # 55007123. Can't find the discontinued part. Is there an alternative? Steve
Hey All, I have problems signing in with my former account WolverineCub. I requested the password a number of times but never got the e-mail even though it was sent. I also contacted the Forum but no Reply. I got a new account so I need the two merged. Thanks Steve
OK, Thanks. Does anyone have a Lund #19040 Sun Moon Visor for Sale?
Looking for one of these. I see the numbers a mixed up. Got one? Or the correct Lund #. I know it's and old thread but there must be one out there.
2.5 Liter Valve Cover Gasket
Thank You MJ Maniac, I see Dorman has the Aluminum VC, didn't know it existed. Steve in Montreal -
Which Permatex, Form a Gasket? Which type? Thanks for the info and Colorado Red. Steve in Montreal -
I have a Fel-Pro gasket to change. It is cork and rubber. Should I add and gasket cement? The valve cover had been changed a while back, does it warp? I had sweating, I slightly tightened the bolts and got more leaking. The Jeep is going in for Painting, I wonder if I can still get the Red from 1988? Steve in Montreal
I got it on eBay from CARID, $33.00 Total. I'll have to fix it. Too late for return. It blows strong. http://www.ebay.com/itm/700126-TYC-HVAC-Blower-Motor/311597669817?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Same reviews, Negative feedback, haven't got the Time. Leaving for Niagara Falls to Repair & Paint.
I need to know if there is way to Identify the year on my 5 speed manual Transmission. The Truck is 1988 but may have a 1987. In 1987 the AX5 used different input bearings and used both the snap ring and nut option on the end of the countershaft. From 1988-2002 the AX5 came stock with the 23mm wide input bearing and the snap ring on the countershaft. Thanks Steve In Montreal
How to install a Floor Pan.
Thanks Guys, You are da bomb. Going in for a paint job this Month. Steve From Montreal -
??? I fixed the driver's side with overlapping good metal, body cement and rivets. Now I have a passenger floor pan that is flat. Do I cut out the ridge on the floor? Steve in Montreal
I'm looking for a good fit carpet for my 1988 Jeep Comanche? I've seen a few on ebay, are they all the same? Steve in Montreal
Thank You Guys. I got two sets of older Flares but the Jeep is being painted so I was interested in New. I bought the Retainer kit, I may be able to adapt the back retainers. The Comanche is a 1988 4 Cyl 2WD Standard. Most of my fixes came off of a 1986 Comanche 4WD with V6 that developed blow-by and was carburetor so it's in my Yard.
1988 2.5L Comanche won't Start
Chassis Ground was the Problem. Don't see an open GND wire, put one. Thanks Steve -
Only 3 Volts at Courtesy Lamps (Glowing), guess the same elsewhere. -
Good ground -
Hello, Thank You... No power at Pump. No Cigarette Lighter, no Radio, No Headlamps, No Interior Lamps (They glowed a bit at first) Fuses check OK Steve -
Hello, I'm new here from Montreal, Canada While heading out on Vacation, my Comanche's alternator pulley came loose and the serpentine belt came off. (the pulley was put on a RB alternator by a impact gun) I was dead on the road but remembered a Canadian Tire was a short distance away so I removed the belt and drove to it. I removed the alternator and had it tightened. (same way) I reinstalled the belt and tightened up the power steering adj. for the belt. Then, the Comanche would not Start. I got towed back home. Besides not starting, the fuel guage was pointing to the Floor which looked like the Crank position Sensor but that was OK. I got Spark but no Fuel. There is no voltage to the pump. Fuses check Ok, the fuse box is Ok, no corrosion. Thanks For any Info Steve
