ComancheLee
Everything posted by ComancheLee
Looking at the RC 4.5 Lift for my 1989 MJ 2WD. My question is, Can i use it on my 2WD MJ or is it only for 4WD MJs
The cooler line connections that connect to the aw4 transmission on my 89 jeep Comanche were leaking when to change both out and as i threaded one of the line connector in to the aw4 trans in snapped the threads on the housing, my question is can just but a weld in the whole and only have one transmission cooler line or will it cause problems,
89 MJ 4.0 Ticking noise during acceleration
ComancheLee replied to ComancheLee's topic in MJ Tech: Modification and Repairs
Yes it does get worse with more gas, I'm using 10w-40 mobile one full synthetic, wear should I stick the screw driver to the block? -
Changing diff fluid Dana 35 (SEE PICS)
Thanks, my truck is at an angle lol that's why I was tempted to take the cover off thx -
Rear Disc Conversion Questions
Cool thanks fellas -
What diff oil goes the Dana 35 and do I need to add any friction modificer??
Windshield Wiper problems
1989 Jeep Comanche 4.0 Auto and I can't tell if the fuse is bad it has a silver case around it. It's not your typical fuse. I only put the paper clip in for a hot second to see if I could get the wipers to work. Thanks for your info -
In the process of doing the rear disc conversion on my 89 Comanche Dana 35 none clip. My question is could I run the stock master cylinder and brake booster? Or will I have to upgrade??
So my wipers don't work I tired putting a paper clip where the fuse goes and I still got nothing, does this mean the motor is bad or is the an issue with the wiring
Found it thanks bro
I'm tired of looking at my clear coolant resivor, I've seen guys with nice metal ones, does anyone know were I can buy one from??
Working on my 89 Comanche doing a read disc conversion on a Dana 35 none C-Clip Removed the axles and noticed that the tapered bearing on the passenger side is damaged. Can I and How do I remove the Bearing race from the axle tube please help
What opening degree thermostat for the 4.0??
What oil are you guys and gals running in your Comanches 4.0 liter preferred,
Will theses wheels fit a Jeep comanche
Lmao alright
