If you have a wrecked (front end) short wheel base Comanche, I am looking to make a trailer to match my 90 Pioneer. I am located near San Antonio Texas. The closer the better. (I already have a bed)
In reply to fiatslug87. No bumper is legally needed for inspection. I just don't want to go thru the hassle of mounting license plate and rigging up lights then redoing the whole thing again to mount the bumper. Actually only rear license plate and lighting needed for inspection
Really need the brackets. Does anyone have an old beat up bumper lying around? Spent $300 on getting bumper redone, just need a set of factory brackets. Can't get the vehicle inspected without the bumper mounted.
Did a visual check on the pins and everything looked ok. 92 bulkhead connector and dash harness as well as dash. Will do a closer inspection on ecu connector today. Thanks for the help
Swapping a 92 xj obd1 wiring harness into 90 Comanche 4.0. Engine turns over fuel pump engages but no power to coil, distributor, crank sensor. Power to all fuses, relays in fuse box. It was an auto xj bypassed the Nss. Any suggestions?
