Cabrarra
1 Follower
516 profile views
Cabrarra's Achievements
  1. Hello I'm stumped on my running lights and my fuel gauge and also battery is getting drained? when i pull the headlight switch it keeps blowing the 10 amp prkng fuse ? ive followed the wire from fuse block which is a red/blk tracer that runs into the harnes under dash where i do not know I'm told maybe the ICM ? which ive already had to replace, I have posted his same problem in my jrwhite3230 account which i can't access so i created this one as for the fuel gauge it is a tan wire does anyone know where that goes to and what is the voltage on that? thanks for any reply ill try to post pics of everything too.
  2. jim I'm jrwhite3230 i couldnt access my account so i created this one
  3. its a 1989 jeep comanche 4.0 which was bored 50over so its 5.0
  4. hey cruiser this is jrwhite i couldnt logg into my jrwhite3230 account anyways to answer your last question is yes its actualy all my running lights when i pull my headlight switch it keep blowing the fuse which is the prking 10amp fuse and also my fuelgauge does not work and my battery is being drain which i suspect the whole problem is on that circuit(wire red/blk tracer) <--which i followed as far as i could but goes into harness to where i don't know ??maybe IcM <---which i just had to replace due to circuit coard fried .now I'm spooked ,because this might be why original ICM fried in first place, what i need is a schematic thaat shows the headlight switch wireing in laymans perspective if its out there?
