Well, I sold my XJ, so that was nice. Had ZERO responses on Craigslist, but I lowered the price $300 and with 12 hours had 3-4 people tell me they'd more or less buy it sight unseen.
Got a few minor things done this weekend on the Comanche.
Replaced passenger seat belt buckle and driver-side window crank. Both were broken.
Also, I began sanding down a bit of surface rust near the rear wheel well on the passenger side of the bed. Luckily, it's only surface rust. My orbital sander struggles a bit with it, so I may need to step it up to something stronger... wire wheel? There are some spots of metal that I will need to grind down to even out the area and make it smooth again. This may be accomplished with bondo.
Once I take care of that, I'll hit it with some of the high performance rustoluem.
I tried peeking under the carpet in the cab, but could not figure out the best way to get it up. I removed the plastic trim piece under the door and pulled it back a bit, and I could not see anything. I imagine I'll need to remove more to be sure, but in the few inches I saw, I saw no signs of rust.
Ordered an OEM 195* Thermostat. The previous owner put a 180* in, and after all the reading I've done on various websites and forums, I'd rather have the OEM 195* in there.
