Coming home tonight and went around a corner and then had a grind and then a boom sound from somewhere in the rear end. After that I had no power and ended up stuck on the side of the road. I've been able to narrow it down to somewhere in my rear axle, but am not sure exactly where. I have a Dana 35. In 2wd the driveshaft will spin but nothing in the axle seems to move. Luckily i wasn't to far from home and was able to drive home in 4wd. When its parked and in neutral, the driveshaft can spin able which i know isn't good. Could it be a ring or pinion gear or possibly a axle shaft? Would it be easier to just rebuild the axle or am I better of trying to find something at Pick-N-Pull? I'm on a high school budget, so I can't go to extreme. Also, is the Dana 35 a floating or partial floating axle?
Thanks in advance I need all the help i can get. :help:
