Tyler Tafjen
Everything posted by Tyler Tafjen
  1. Hi guys, I got a '86 2.5 with an AX-5 and 4x4, recently my master cylinder started leaking so i decided to replace both the master and slave cylinder. Looking at the Slave cylinder, it seems near impossible to reach the top bolt on the slave cylinder. Its an external cylinder. Does anyone have any ideas? Do I have to drop the tranny or can it be done? Thank you
  2. Well I was finally able to tear into my axle and I did not break an axle shaft but shattered my carrier and the spider gears. Should have some fun changing those! http://pic20.picturetrail.com/VOL1453/13671596/24504341/408528972.jpg
  3. Thanks for all the help. I'm in the process of finals so i can not pull the truck apart until sometime this weekend. In swapping an axle, is is just re weld the spring perches? Also what kind of axles should i be looking for? Dana 44? 8.25?
  4. Coming home tonight and went around a corner and then had a grind and then a boom sound from somewhere in the rear end. After that I had no power and ended up stuck on the side of the road. I've been able to narrow it down to somewhere in my rear axle, but am not sure exactly where. I have a Dana 35. In 2wd the driveshaft will spin but nothing in the axle seems to move. Luckily i wasn't to far from home and was able to drive home in 4wd. When its parked and in neutral, the driveshaft can spin able which i know isn't good. Could it be a ring or pinion gear or possibly a axle shaft? Would it be easier to just rebuild the axle or am I better of trying to find something at Pick-N-Pull? I'm on a high school budget, so I can't go to extreme. Also, is the Dana 35 a floating or partial floating axle? Thanks in advance I need all the help i can get. :help:
  5. Thanks for all the input. Got to get some $$$ before i can do anything but ill defiantly keep this in mind.
  6. I'm new to the site and recently picked up an 86 2.5L with a 5 speed and 4.10 gears. I know its a 4cyl but it just doesn't have the power to make it up some of the hills in town anywhere close to the speed limit. Are there any upgrades (other then motor swaps) that will increase the power and performance? Right now it is fully stock, but I'm planning on putting on a 3" lift and 31s before the winter starts here. I have heard about throttle body swaps and different injectors, but i don't know where to start. Any help would be appreciated.
