Diamond
    Kansas
  • Interests
    Comanche maintenance, upgrades, tips and tricks, advice and opinions on parts, techniques and equipment.
773 profile views
Diamond's Achievements
  1. I am one of many it seems who could use a functional unit. If by chance someone has a unit for an 88 longbed 20? gallon tank, I would like to buy it dia3132@outlook.com. Thanks.
  2. Thanks for this documentation. I am just now coming to this project and was glad you have found a good fix with the tank/pump swap. Do you have any add'l comments, recommendations, etc. on this now that it is 6 months later? Hope you are still running strong.
  3. If you end up changing your mind and getting a different sending unit, I'll buy the 91-92 HO unit from you. Mine is leaking and so far no response to the wanted request in the classifieds. Thanks I'll definitely let you know if I do. I haven't been able to find a renix era one out here at all. Just throwing this out there for others who might make the rookie mistake I did over Memorial Day weekend. I pulled my sending unit because it did not seal and would leak gas if the tank was filled. Low and behold, the wire to the rheostat was compromised (it was hanging by a thread and read inaccurately anyway). So now, finding out that none are available unless I score one from a forum member, I am driving a truck with an inoperable gas gauge. Hail to the engineer among us who can find some other sending unit that can be rigged to the fuel pump!
  4. I would like to come across a set of rear shocks that are not too old and/or do not have too many miles on them. I just put some Ultras on the front but would consider a set of four if premium. Thanks.
  5. I would like come across a pair of shocks that are fairly new and/or have not seen too many miles. My truck is stock. I just installed a pair of Ultra's on the front, but would still consider a set of four.
