awhpoo
Contact Methods
  • AIM
    Pacodiego06
    Cali
awhpoo's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. those pics of the shop are only a few of the things that we were able to do there most of the work was done at home on the dirt floor in the heat i mean i do live in cali it was 105 today :oops:
  2. 7.5" rubicon express coils 2" pucks and just sprung over in the rear it sits a lil bit high in the front at the moment but i havent put my revolver shackles on yet.
  3. first run out with it its pretty much done other then paint bumpers rock rails and some trimming :waving:
  4. yea we removed just the inside half of the lca mounts so far but will remove the entire mount and clean it up.
  5. Got my y link upgrade all set up to go so here the pics. :cheers:
  6. Got quite a bit done in the last few months since i have updated. It is now running no check engine light on no codes came up purs like it was never wrecked.
  7. Thank you. Got part of the roll cage in today hoping to get some of that mocked up but will be mostly checking out the front air locker in our Cherokee, it sprung an air leak, its not good when airs coming out the vent tube right??? lol.
  8. i got a quick question what are some of you guys doing for rear leafs?? I don't really like add a leafs was going to go with the stocks soa with a ubolt elim kit. Just curious on what u guys are running or if you have found any places that sell like spring.
  9. well finally got the engine all together here's a few of the process had to dig out the valve machine During after Doing the seats on the head putting springs back on and together and then back on the block got the valve cover back on i have put it completely together ready to drop it in when the time comes just didn't get any pictures of it. Got the old 4 cylinder out and the tiny transmission took the pressure washer to the engine bay also got the back half cleaned off got the grinder out and took a bit to dig more in the rust spot and found from the bottom not to bad i have seen worse looking at others pictures here. Got the fiberglass out and patched it right up. thats about where we are at right now can't wait untill this 3 day weekend to get some primering and other stuff done. Thanks for lookin! :brows:
  10. been pretty busy striping the mj all down and getting it ready to go back with the 97 stuff got a ton of pics I'm working with atm they are on the way. :cheers:
  11. well i got a bit of work done this weekend. what it started out lookin like. to a rather quick. taking the plastics off to get to the carpet. and after we got the carpet out i was suprised at what we found. the worst bit of rust in it. other then that it looked really good. and after a bit of sanding and a shot of flat black till we primer it. getting it ready for the cage to go in and then going to start to install the 97 dash and seats.
  12. can't wait to see it
