mknherhappy
Everything posted by mknherhappy
Violent Shake? Any help?
mknherhappy replied to mknherhappy's topic in MJ Tech: Modification and Repairs
No, does not pull in either direction and runs right down the middle of the lane. -
Installed 1 3/4" coil spacers, new shock, new stearing stabilizer, new sway bar, and had the tires balanced over the weekend. Everything went ok, however, now when I hit a bump in the road with both tires I get a violent shake up front, the greater the speed, the worse it is. If the bump in the road hits both tires at the same time, no problem, the problem happens if there are bumps that hit one tire then the next. Before the lift, there was a little bit of it going on, but I figured it was the worn out shocks and steering stabilizer. Any help or suggestions would be greatly appreciated.
You get the Shackles installed? How did it go? I'm still waiting to mine to show up in the Mail... SW2 The Shackles went great, really no problems at all, did it just like the description said listed above. Coil springs on the other hand.....did not go well, ended up renting a set of strut compressors, after I could not get the coil spring compressors to work.
89 spark plugs the same as 88?
Ya, the older I get, the more common this happens..... -
Went in last night to buy spark plugs for my 88 MJ, the l isting only went back to 89. Is the "1989" 4.0 engine the same as the 88? Thanks again for your help.
How do you remove the wiper arms?
So that tab will slide away or to the right of the arm? Thanks for the picture. -
Anyone know how to remove the windshiedl wiper arms? Want to take them off to paint them. Thanks again for your advise.
Need to keep the benc seat in my MJ, looking for any options for a console or anything to keep a bottle of pop and cell phone secure. Tried the cheap plastic things, but, they move all over. Any advice would be appreciated. Thanks,
Looking to replace the valve cover gasket on my 88 MJ with the 4.0. Any opinions on the best type of gasket? Thanks again.
Can Comanche Wheel bearings be re-packed?
Any way to tell if they are bad, or need replacing? 1988 MJ, with 69,000 miles. Thanks again. -
4 Wheel Drive -
How difficult is it to do? Is there any online tutorials? Thanks again for your help. -
Just wanted to thank everyone for their help, I have asked lots of newbie (stupid) questions and not once have I been chastised for asking stupid or redundant questions. Thanks again.
Can anyone tell me how to remove the side vents? Is it difficult to do? Thanks again for your help.
The bench seat in my MJ will not move. Any advice on what could be wrong?
