mickeyd
Everything posted by mickeyd
  1. That is more than I through, don't ever see any around Okla. city.
  2. Steve sent you a PM today. Just now findout about the problem. I order one in January that i have not installed. Thanks
  3. Can anyone tell me if a sterring column out of a 1991 MJ will fit a 1989 MJ. I know the stop light switch is different, is that all? They are both floor shift auto trans.
  4. Steve I need a medium grey for my 89 comanche, if you have any left
  5. Thanks crusier 54. I will check this. Everbody likes to point to the basic ie plugs wires but they will not cause the tac to go dead like my. Minuit i have never seen a 02 sensor cause a miss, you are right about fuel milage. What ever this is it's causes the tac signal to drop to nothing
  6. I have a 1989 comanche with a 4.0. The motor started miss a little today. Doesn't do it all the time but when it does the tac drops to 0 then junp back up. Where does the tac pull the signal from? Thanks for any help.
  7. Thanks for the info mvusse maby some one will read this and know for sure if this will work or not. Dadinator not for sure if your 1990 TCU is different than my 1989 may be the same TCU.
  8. Purchase a 1991 cherokee laredo today for my donor car. It has 4.0 4wheel drive and automatic. What problems can i expect to run in to when installing in my 1989 comanche. I am changing the transfer case, front axle, transmission and front driveshaft. I know the rear driveshaft will have to be made.
  9. Found a 1994 jeep grand cherokee rollover today for 500.00 still run and drives. Has the 4.o engine four wheel drive with an automatic, will this make a good donor car? I know that it has cv axle instead of u-joints, is this better or worse? It's also has 4 wheel disc brakes, will they be a problem to used on my comanche? Thanks for the help.
  10. Thanks mvusse and pete m for the info. I think this will make my job easier.
  11. So with my automatic transmission I can use 1989 to 1996 front diff and transfer case . What automatics transmission will be best. On my conversion to 4 wheel drive
  12. Sorry to put you out so much frank the dog. Hope you are having a bad day and not like this all the time. My jeep is an automatic. I will be running a 31 or 32 tall tire. The truck came out with 215-75r-15 now has 235-75r-15. Pete m I will check the vent line thanks for the info.
  13. Hello comanche club members. MY name is Mickeyd, new to the form. Today i purchased a 1989 comanche eliminator, i believe the motor to be a little weak, it has the air filter box full of oil. The truck has 177,000 miles and i purchase it from the man that purchased it new. Now for some help, I want to convert it to a 4 wheel drive. I was thinking about buying a cherokee donor car for all the parts. This way i will have a spare motor to rebuild. What are the best years to buy or does it make a difference? Any help would be great. Thanks Mickeyd
