windshield
The window has a better chance coming out in warm weather if you're going to take it out .
At least you have the weather going for you CJ. :yes:
Lol. The urethane is softer in the heat and is easier to cut through and make damaging the windshield less likely is what I meant . Thanks Don
I got the windshield fixed. Took it back down there and they re-sealed the windshield from the inside. Took them about an hour to do and all is good there now. I started pulling the plastics out of truck 1 to clean them and also to run some new wiring. I just discovered my back glass has been leaking for quite some time. The lower corners around the glass are rusted badly. Has anyone else encountered this problem? Unfortunately I don't have any metal working skills so will have to take it to a body shop to see if they can fix it.
