86XL Posted January 21, 2015 Share Posted January 21, 2015 Are they compatible? I have an 86 Comanche and I have a 89 Cherokee parts truck at my disposal. Can i use the XJ fuse block in the MJ? Or on the fuse, #17 Gauges wh, the tab # 11 14YL broke on me. What is the easiest/temporary fix so I can get my truck smog-ed then I will have a little more time and move the whole blessed thing to the engine compartment. Thank you Link to comment Share on other sites More sharing options...
mnkyboy Posted January 21, 2015 Share Posted January 21, 2015 You can just replace the pins with new ones, no need to swap boxes unless the box is damaged. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 21, 2015 Share Posted January 21, 2015 http://comancheclub.com/topic/45231-fuse-block-dissection/?hl=terminal&do=findComment&comment=460388 Link to comment Share on other sites More sharing options...
86XL Posted January 21, 2015 Author Share Posted January 21, 2015 thanks for the help. Link to comment Share on other sites More sharing options...
86XL Posted January 22, 2015 Author Share Posted January 22, 2015 I had such of a wonderful time to find these, http://www.delcity.net/store/1!way-Fuse-Block-Terminal/p_11128 But I did and its fixed. thanks again Link to comment Share on other sites More sharing options...
