Automan2164 Posted June 7, 2010 Posted June 7, 2010 Thanks for taking the time to register your Comanche. It will help us all to understand how many are on the road, and how many are resting in the trails of the sky. Here is the general format: Year, Make, Model. Image, if available Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase Build date: (its on the driverside door sticker, in the form of month and year) Current Location: Region will do, state, and area of state. Status: Is it still on the road, is it in the junkyard? Project awaiting work? Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort. Thanks again! Rob L. for ComancheClub.com
MiNi Beast Posted December 5, 2020 Posted December 5, 2020 so glad i read this first. thanks. I'm enjoying.
