I'm turning my 1992 comanche eliminator with a 4.0 and ax-15 from a 2wd to a 4wd with a 242 transfer case. I was wondering if the wiring in the 2wd has the wires to light up the 4wd lights on the dashboard and just aren't being used. Bulbs are in place. I obviously don't need these lights since I can look down at the shifter if I want to know what position the transfer case is in, but I figured if the wiring is there I might as well use it. What colors and where would I look for them. Thanks
You do not need any wiring for the Tcase, specifically. The wires going from the back of your transmission are for your speedometer.
i know i don't need wiring to make the system work. The wiring I'm talking about is the wiring that goes to the switch on the back of the transfer case that lights up the part time and full time lights on the dashboard. I think it's the same place where the vaccuum lines on a 231 connect.
