deziped Posted June 21, 2008 Share Posted June 21, 2008 Here's an easy fix for doors when the hinge holes become oval shaped & doors slop around. Do to the limited space to work with I just pulled my doors off, about 20 mins each door. I then hammered the old pins out & ran a 17/64 drill bit through all the holes. That returned them to a near circular condition. A 9/32 would have made them complete circular but I didn't have a pin/bolt that size on hand and neither did the hardware store. But, I discovered that their nail bin had 6 1/2" spikes with a .260" dia . They fit the bored out hinge just fine when cut to length. Cost 0.10cents. Door lines up with striker and closes with ease now. Link to comment Share on other sites More sharing options...
Wildman Posted June 22, 2008 Share Posted June 22, 2008 ahh......the only problem I see with using a pole barn spike is it's not harden, and could wear out kind of fast. But cheep enough to replace every so often. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 22, 2008 Share Posted June 22, 2008 Here's an easy fix for doors when the hinge holes become oval shaped & doors slop around. Do to the limited space to work with I just pulled my doors off, about 20 mins each door. I then hammered the old pins out & ran a 17/64 drill bit through all the holes. That returned them to a near circular condition. A 9/32 would have made them complete circular but I didn't have a pin/bolt that size on hand and neither did the hardware store. But, I discovered that their nail bin had 6 1/2" spikes with a .260" dia . They fit the bored out hinge just fine when cut to length. Cost 0.10cents. Door lines up with striker and closes with ease now. Don't know if you have the Tractor Supply chain out there, but they have these pins in case hardened steel. Link to comment Share on other sites More sharing options...
deziped Posted June 22, 2008 Author Share Posted June 22, 2008 I took lack of hardness of the spike into consideration. But I figure they will be really easy to pop out when they show wear. With the big head and having cut em a 1/4 inch longer a tap with a hammer & vise grips should make the next pull out easy. Used lots of never-seez also. I'll check on-em in a year or two. ;) Link to comment Share on other sites More sharing options...
