What set are you referring to? The adjustable or the fixed length one's?
They all have poly bushings on both sides = less flex, and harsher ride. Plus it doesn't look like they are greasable (as must with poly). Poly isn't horiable; but just run it on one side so you still have flex (flex joint on one end is preferred).
Rock Kralwer adjustable's are $10 more and are solid stock with flex joints and a liftetime warranty...
