4 liter valve cover breather?
Anyone know where I can get the rubber bend bit that comes out the center of the valve cover? I went to the stealer and asked for this piece and apparantly it wasnt sold separately. I would have to buy the entire set of vacuum/breather hoses which would cost me almost 400$ :nuts:
Being in Norway I don't know if this applies... I would just go to the junk yard.
Maybe one of these guys could grab one for you when they go and ship to you there?? I would do this, but I don't generally go to the JY anymore...
CW
:hmm: That doesn't look like anything I have seen on a 4.0L CCV system. He is asking about a rubber part which I believe to be the line on the forward end of the valve cover and should be able to be found in the aftermarket for much less than at a dealer. I know NAPA has them here in the US, but not sure about Norway.
My bad, i thought it said 4 cylinder. You can get them from napa. You have to buy the assembly not just the rubber. I have an extra assembly because I just replaced mine that you can have for the cost of shipping. Or if you want to send the money i will pick one up from napa and ship it to you. If you want to replace all the ccv lines it come to a little over $50 from napa.
http://www.napaonline.com/masterpages/N ... entilation
